| clay bar i recently tried the clay bar system , and i was amazed at the results , it doesn't really substitute buffing or wet sanding , but paint you think is clean and washed can be so much better if you use the clay bar and cleaner wax . if you run your fingers and hand over the paint and it feels even a little rough or sticky , then clay bar it and it will be slick as glass and soft to the touch . i didn't want to mention any company's that make since i don't know if i,m allowed , just wanted to give my input . |
