Chemicals To Re-Clear Coat Wheels - BMW Forum - BimmerWerkz.com
Old 12-10-2006, 07:25 PM   #1 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I'd like to know if there is any great marvelous chemical out there that can take off the existing worn out clear coat...
I have Hamann HM2s... they have about 150k miles on them... a little road rash which I know I cant fix... but the clear coat seems to be turning yellowish in areas... and pealing off in others... I'd like to take it off and re-clear coat it...
What do I need guys?
Thank you,
Les
1997 E36 M3 1990 E30 325i
Old 12-11-2006, 09:52 PM   #2 (permalink)
Toto's Avatar
Toto is on a distinguished road
You might check with some high-end used car dealers and see if they have a contractor that refinishes wheels. We have one here in the KC area that can remove and re-paint clear coat, fix nicks and scratches, etc. They are typically independent contractors and go to many dealerships to perform this work.
Toto
Toto is offline   Reply With Quote
Old 12-11-2006, 09:54 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Wow... good idea... thanks.
Les
Old 01-18-2007, 03:13 AM   #4 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
ya, thats my suggestion, or just have them completely stripped and powdercoated
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-23-2007, 01:38 PM   #5 (permalink)
Car: 2000/323ci/bmw
inkyman is on a distinguished road
I have actually removed the clearcoat and resprayed my wheels before.
I bought a can of aircraft stripper that you spray on the rims after you mask off the tires.
This will cause the clear coat to peel off before your eyes.
I bought the stripper at Wal-mart.
I also purchased a can of spray clearcoat at Wal-mart that work great.
The rims looked new !
inkyman is offline   Reply With Quote
Old 11-01-2007, 12:09 AM   #6 (permalink)
zr3
zr3's Avatar
zr3 is on a distinguished road
ditto above its not mysterious clear coat !! its clear coat like the rest of the car , i have redone 3 sets of wheels this way , ( i build allot of cars ) any paint stripper will do how ever , aftermarket wheels seem to not have as strong of clear coat as some factory wheels , ive had to resort to bead blasting the rest off on a set of corvette wheels because many coats of stripper didnt fully remove all the clear coat , when you DO get it all off , then re- clear coat . a note here its a double edge sword , the wheels need to have a small amount of bite for the new clear coat to stick to , i did this to a set of momo rims and i made the rims look like a mirror before re-clear coating and then it peeled a year later , your shine will come from the clear coat and the rims dont have to be polished like a mirror //// one more note , most rims that look ugly just need this procedure and can look like new again !!
zr3 is offline   Reply With Quote
Old 11-01-2007, 12:14 AM   #7 (permalink)
zr3
zr3's Avatar
one more thing , the better the clear coat the better it will hold up , the wheels take a beating the rest of the car never sees , there are better and worse quality's of clear and of course powder coating , duplicolor makes a clear coat just for wheels with a little metallic in it , but i haven't tried it yet . good luck and don't be afraid to do it !!!
clear coat is commin off! bob318 3-Series (E36) 4 03-10-2006 09:38 PM
Clear Coat Or 3m Scotchgard?` benson8 3-Series (E46, E90) 2 12-09-2004 05:54 PM
Can Milk Spoil the Clear Coat? CableGuy Wash & Detail 13 08-25-2004 12:44 PM
2001 Clear Coat Flaking Off bryno540 5-Series (E12,E28, E34, E39, E60) 6 08-01-2004 08:13 AM
Chipped clear coat. Mattitjah 3-Series (E36) 4 04-26-2004 07:07 PM
