I was finishing the brake job last night on the Bimmer, and noticed some very light rust around the edges of the wheel well. I was thinking some light sandpaper (say, 400, 800 and 1000 grit) followed by a prime and paint to remove it. Any thoughts?
How hard is it to do this? The rust hasn't penetrated through metal, and I can definitely remove it without wearing through, but any words of advice?
__________________ Proud member of the 100,000 mile club
Proud member of the I Hate SUVs club
If it is as light as you make it sound, the first thing I would try would be to clay the rust. I know that sounds funky, but I have had it work with small rust blooms on all types of vehicles.
You don't have to use sanding paper and risk damaging your car. WHen i had a similar problem i went to autozone and bought rust remover. Its a jell/liquid solution that removes the rust without much effort.
Originally posted by MaThGr82+Mar 27 2005, 08:28 PM--><div class='quotetop'>QUOTE(MaThGr82 @ Mar 27 2005, 08:28 PM)</div><div class='quotemain'><!--QuoteBegin-Casey3561@Mar 27 2005, 04:36 PM Since it's under the paint, how do I do this? Scrape off the loose paint then apply the remover?
[snapback]319638[/snapback]
If it is "under" the paint, how in the hell can you see it. Wouldn't it be "under" the paint and therefore not visible to you???
I guess I don't understand. Can you take a pic of it?
[snapback]319681[/snapback]
[/b][/quote]
Maybe it's under the clear-coat? Doesn't rust only occur as a result of the oxidation of metal? e.g. the metal IS rusting.
If it is "under" the paint then you could see the paint start to bubble out right? You don't actually see the rust just a bit of a bubble and maybe some cracks from it.
There's some bubbling and minor cracking. When I say it hasn't penetrated, I meant that it hadn't broken through to the other side- i.e. it could still be sanded.
