what size wheel spacers needed? - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > Site > Test Forum
Test Forum If in doubt test your post in here first! Post counts do not count. This forum is emptied periodically!
Old 01-12-2013, 04:55 PM   #1 (permalink)
bb525i is on a distinguished road
i have recently been given some 18x8 and 18x9 1/2 wheels for my 94 525i. i tried putting them on today and the 18x9 1/2 won't fit on the back due to the rim hitting the lower control arm. my question is what size spacer is needed to clear the lower control arm. thanks for the help
bb525i is offline   Reply With Quote
Old 01-12-2013, 09:17 PM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Throw the rim back on, see what the gap is from proper fitmet to the wheel hitting. Then add 5 mm.
Click HERE to see my E36 Blog
Old 01-13-2013, 10:55 AM   #3 (permalink)
The wheel is hitting the control arm before it gets anywhere near the the hub. Not sure how i would be able to get measurement if i cant get it on. Any suggestions are appreiciated
Old 01-16-2013, 09:54 AM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
I run 18x8.5" wheels in the back with no issues at at all. Your probably gonna need a 1/2" spacer at the very least. With that big a spacer you should get a wheel stud kit. The last time I saw a 9.5" wheel was on an E39.
Old 01-20-2013, 04:14 PM   #5 (permalink)
I have a stupid question but its because i dont know. The numbers on the back of the wheel next to the "et" is that the offset? If so. The rear are 45 and the fronts are 35. So would a half inch spacer be enough for cleareance. And should i also get the same spacers for the front
Old 01-20-2013, 11:56 PM   #6 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Ivan413 is on a distinguished road
Yes the numbers next to et are the offset. Et is just another way of saying offset. Me personally I would go with a 15 mm spacer. This will give u plenty of clearance while adding a more aggressive stance/ profile to your bmw.
Sent from my iPhone using AutoGuide.com Free App
Just your avg 17 year old with an e36 318i as a DD!
Ivan413 is offline   Reply With Quote
Old 01-22-2013, 09:40 AM   #7 (permalink)
What is 15mm in inches? Half inch or a full inch?
Old 01-22-2013, 01:22 PM   #8 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
6/10 of an inch or 6cm which is a little bigger than .5 inch which is about 12mm
Sent from AutoGuide.com Free App
10mm wheel spacers jgoodman@attglobal.net Wheels and Tires 0 06-08-2007 02:51 PM
What Size Wheel Spacers Would I Need? emmceethree 3-Series (E21, E30) 3 02-12-2005 11:51 PM
Wheel Spacers dado 3-Series (E46, E90) 0 09-30-2004 06:28 PM
Wheel spacers for E46? GnarlyCow 3-Series (E46, E90) 0 06-21-2004 11:09 PM
wheel spacers buuhh99 3-Series (E36) 5 03-13-2004 01:49 PM
