Scosche HD Amplifiers - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > Supporting Vendors > Scosche Industries
Scosche Industries Scosche Industries
Old 09-17-2012, 02:34 PM   #1 (permalink)
Supporting Vendor
ScoscheCarAudio is on a distinguished road
HDA4002 - 400 Watts Max 2-Channel Amplifier
$99.95
HDA8004 - 800 Watts Max 4-Channel Amplifier
$129.95
If you're in the market to boost your audio system, check out Scosche HD amplifiers.
Scosche HD is designed for value without compromising sound quality or components. The HD amplifier line-up includes 2 amps. The 2-channel 400 watt amplifier (#HDA4002) boasts a 50 watts RMS x2 at 4 Ohms power output. The 4-channel 800 watt amplifier (#HDA8004) has 50 watts RMS x 4 at 4 Ohms power.
Features
-Thermal overload protection
-Sturdy Aluminum Side Panels
-RCA and high level inputs
-Brushed Aluminum Heatsink and Top Plate
-Dynamic bass boost
Questions? Contact Scosche
ScoscheCarAudio is offline   Reply With Quote
Old 02-03-2013, 06:21 PM   #2 (permalink)
Supporting Vendor
Arriving Spring 2013!
Scosche HD 5-Channel Amp & HD Mono Amp
The two new HD amplifiers both feature Class-D topology, thermal overload and short circuit protection, variable crossovers, MOSFET switching power supplies, RCA and speaker level inputs, brushed aluminum heatsink and top plate and dynamic bass boost. In addition, the 5-channel amp and MONO amp have a bass knob included.
The new 5-channel amplifier (#HDA5CHANNEL) is the first all-digital amplifier under $300.00. It’s full-range channels boast 50 watts RMS x4 at 4 Ohms while the subwoofer channel outputs 250 watts RMS at 2ohms for full system power. It also features a separate front and rear input summing, remote bass control port, and selectable gain range.
The 500 watt mono block (#HDA1001) outputs 500 watts RMS x 1 at 2 Ohms and is a full-featured mono amp for under $200.00. It features a power protect indicator, speaker level input and remote bass control port.
Both amps will be available for purchase by Spring of 2013.
Scosche Retailers - M.E.S.A. ScoscheCarAudio Scosche Industries 0 09-10-2012 01:14 PM
Scosche reNUE pro c2 USB Car Charger ScoscheCarAudio Scosche Industries 0 08-30-2012 03:55 PM
Scosche HD Speakers ScoscheCarAudio Scosche Industries 0 08-15-2012 03:29 PM
Welcome Scosche Industries! administrator Scosche Industries 3 06-05-2012 03:38 PM
do we have external amplifiers buuhh99 Audio and Electronics 19 07-13-2004 02:42 AM
