This has got to be on everyones' list of thing to do. It is by far the most noticable upgrade you can do. This transmission feels like it's brand new. The throw is short not much increase in effort and almost no slop at all. Insallation took me about an hour. Absolutly FANTASTIC !
The next thing is to get rid of the CDV ( Clutch Delay Valve ) .
__________________ 98 328is Sport Package M3-Spoiler and Front End,
Turner Motorsports 4 Wheel drilled Rotors.
Axxis Brake Pads, Teflon/Stainless Brake Hoses.
UUC Sachs Stage 4 Suspension.
Sway Bavarian Sway Bars.
H&H MotorSports Front and Rear Strut braces.
Conforti CAI and Shark Injector.
UUC System U DTM Exhaust
UUC Short shifter , Tranny Mounts and Clutch Stop.
F1Danza Lightweight Flywheel with M-3 Heavy duty clutch.
Factory BMW M3 Front Bumper with Splitter.
More to follow...MUCH MORE !
You kidding right ! Too sloppy , there is virtually no play at all. To each His own .
they also comment on the use of other BMW shift levers to make a "cheap" SSK...:
If you have an E30 or E36 318, 325 or 323, then you can swap in the BMW E46 325Xi lever (part number BW-25-11-1-434-148, about $55) to obtain a 29% reduction in the shift throw.* Or, you can swap in the E36 M3/328 lever (OEM-25-11-1-221-977) which basically was a "built-in" short shift to these cars, and offers about a 1/3 reduction in lever travel.* If you own an E36 M3 or a 328, and you want an even shorter throw, you can swap in the shift lever from an M-Roadster (OEM-25-11-2-228-384, about $55).* The bad news is that if you want to use the M-Roadster lever, you may have to bend it slightly to make it fit properly.* Use a bench vise and bend it to match your stock lever.
this is probably the most cost effective way to get a SSK for your car.
Another manufacturer that I like for short shift kits is AutoSolutions which offers an amazingly detailed kit that replaces many shift bushings and eliminates many points of failure for the shifter.
