| If you do let it run in the flat state, does the performance pickup as the engine warms up, or does it stay flat until the engine is turned off and then restarted?
It could also be an issue with the MAF, a simple test with that is to simply disconnect the wire from the MAF and see if the problem disappears, you will be down on power, but it should eliminate the flat performance when first started.
Has there been any work done on the car prior to this issue first presenting?
__________________ Riding in style |
