| Welcome to the Werkz.
Check for any vacuum leaks that might be messing up the air fuel mix. When you start it, try putting your foot hard on the brake pedal, if it sinks when you start cranking and the engine fires then you may not have an air leak, if it doesn't, then start probing around you vaccume lines and the boots between the inlet manifold and the Air Mass Sensor. Good luck |
