| It's on the right side of the trunk in both of them (under the cover/in the floor).
Undo the 10mm bolt to loosen the clamp on the negative post, disconnect it, do the same for the positive. When both are unhooked, undo the battery retainer (may vary) and take it out. Install is the exact opposite of removal.
__________________ |
