Hello, Everybody!!!! '82 320i fuel problem - BMW Forum - BimmerWerkz.com
New Members Check In come in say hello...
post #1 of 4 (permalink) Old 11-13-2011, 09:00 AM Thread Starter
chalunga is on a distinguished road
New owner of '82 320i with fuel delivery problems.
Car sat for several years, drain gas tank and able to
get it running, however starts fine but no power, stays idle
but when under pressure starvs for fuel.
Any suggestions?
Thanks
chalunga is offline
post #2 of 4 (permalink) Old 11-13-2011, 10:06 AM
kerryf is on a distinguished road
Start by cleaning/replacing Fuel Filter(s). Examine fuel lines for damage & correct any problems. If problem persists, dismount gas tank & have professionally cleaned repair. If problem persists, test fuel pump.
Good luck!
kerryf is offline
post #3 of 4 (permalink) Old 11-13-2011, 11:34 AM Thread Starter
Thanks, for for you reply, I will do that next.
chalunga is offline
post #4 of 4 (permalink) Old 11-24-2011, 11:54 PM
hodgepodge is on a distinguished road
Ditto on what Kerryf said.
Any time a car sits for awhile, gunk can mess up the fuel pump and filter.
There is also a fuel pressure regulator on the fuel rail that regulates fuel into the injectors. That could be fouled.
You should also consider disconnecting the fuel line to the fuel rail, putting a bucket under it and cranking the ignition to pump some gas and see what the flow looks like.
The fuel filter is located under the car in the transmission well by the front seat, I think. As for the pump, located near the filter for this model, I think, you should hear it when you are at idle, but it should not be terribly loud. If it is really loud, it's probably toast and can't pump higher volume.
Hope that helps.
Current cars: '99 E39 wagon (200k+), '99 E36 Cabriolet (220k+), GMC Yukon Denali (186k+, but who cares?)
Prior BMWs: '99 E39 (120k), '94 E34 (220k), '93 E34 Touring (320k), '86 E30 (275k), 76 E12 (175k), '74 E10/model 115 (2002 tii) (110k)
BMW's run forever and the Internet is a nearly infinite resource. Use them both wisely for maximum enjoyment and return on your hard-earned cash.
hodgepodge is offline
  BMW Forum - BimmerWerkz.com > BimmerWerkz > New Members Check In
1982 320i fuel problem klwj33 3-Series (E21, E30) 1 09-28-2011 10:26 PM
82 320i Fuel Pump Problem ekr470 3-Series (E21, E30) 5 08-15-2009 10:41 PM
320i Using too much Fuel Mitch_Medic 3-Series (E46, E90) 6 07-07-2009 01:54 PM
320i e46 2004 fuel consumption help abu_gaby 3-Series (E46, E90) 4 05-03-2006 05:27 PM
1978 320i fuel injection problem yo_mang 3-Series (E21, E30) 10 02-21-2006 06:03 PM
