Engine shaking problem e30 - BMW Forum - BimmerWerkz.com
New Members Check In come in say hello...
post #1 of 10 (permalink) Old 09-30-2008, 08:51 AM Thread Starter
bimmer1990 is on a distinguished road
My first post and need a bit of tech advice from anyone who may know.
Have a 1990 BMW 316i coupe. E30 shape with an M40 Engine
The thing is the engine seems to shake/vibrate in a cyclical way. It does this while driving and idling. The vibration can be felt through to the steering wheel and when siting in the driver seat too. The shaking/ vibration cycles through being steady for a second, then shaking for 1 to 1.5 seconds
I know that if I don't try sort it out know, I'll be selling a kidney to get it repaired later on.
I ain't the most clued up when it comes to engines, but I've made a start and checked a few things out, to tick off the list.
Have checked the rotor arm, distributor cap and ignition coil. They all seem in good condition. Have put in a second set of spark plugs but still the same cyclical shaking.
Have recently changed all the belts (timing, PAS and alternator). Also changed the gearbox/ transmission oil and changed the engine oil with to 5w40 synthetic oil.
Engine coolant leak was fixed and the coolant level has been constant for some time.
Had new engine and gearbox mounts put in about 8 months ago.
Not sure what else I can change myself.
Would appreciate any advice on what might be causing the problem.
Thanks!
Last edited by bimmer1990; 09-30-2008 at 08:58 AM. Reason: hit the wrong key, and posted to early
bimmer1990 is offline
post #2 of 10 (permalink) Old 09-30-2008, 10:00 AM
Help from over the pond
marti5's Avatar
Sounds to me as if the timing is to far retarded or advanced, or you have the firing order incorrect as in 2 of the HT leads are on the wrong plugs.
marti5 is offline
post #3 of 10 (permalink) Old 09-30-2008, 03:51 PM Thread Starter
I'll check the HT leads again.
Also how do you go about adjusting the timing? or should i leave it for the garage to do?
I got the haynes manual, a pretty good web site that has colour pics and a step by step guide (Pelican Parts - Porsche Parts & BMW Parts - Automotive Parts and Accessories - Porsche & BMW) and time this weekend.
Thanks again for the info.
post #4 of 10 (permalink) Old 09-30-2008, 04:30 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
I dont beleve it would cycle if it was the cam timing or the Sparkplug lead mixed up... those would just cause it to run horrable....
Have you cleaned the ICV(Idle Control Valve)? WHy was the engine replaced BTW?
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #5 of 10 (permalink) Old 10-01-2008, 07:47 AM Thread Starter
sorry, I mean't I recently changed the engine mounts and the gearbox mounts. Engine was fine, this shaking's just crept up and getting more and more noticeable.
Haven't tried cleaning the idle control valve. I'll give it a go this weekend, when I have another try and check a few other things.
Thought maybe because the tracking and wheel balance was out on the front wheels, that might have loosened something, but the engine still shakes cyclically even when idling.
I'll let you know if there's any improvement.
Thanks!
post #6 of 10 (permalink) Old 10-02-2008, 10:11 PM
lowbuck2 is on a distinguished road
Im curious where it is idling at - and does the engine stall well below 800 or so.....
alpine may hit head-on with the IAC....
lowbuck2 is offline
post #7 of 10 (permalink) Old 10-03-2008, 06:19 AM Thread Starter
the engine idles at about 800 rpm and doesn't fall below that or stall. There's just a very noticeable shake coming from the engine that can be felt through the driver seat, steering wheel and in the general area where you'd sit.
still gotta check the Idle control valve tomorrow. Will let you all know if it solves the problem.
thanks again
post #8 of 10 (permalink) Old 10-04-2008, 01:08 PM
bavarian is an unknown quantity at this point
hi there try cleaning the idle valve as they to tend to go.
bavarian is offline
post #9 of 10 (permalink) Old 10-04-2008, 01:43 PM
marti5's Avatar
PCV valve springs to mind! ?
marti5 is offline
post #10 of 10 (permalink) Old 10-04-2008, 10:14 PM
^ could be a vacuum leak of some sort... Check the intake boot and all vacuum line for crack... if any replace it!
  BMW Forum - BimmerWerkz.com > BimmerWerkz > New Members Check In
99 528i Wheel and Front End Shaking Problem thedude2470 5-Series (E12,E28, E34, E39, E60) 10 12-18-2010 08:51 PM
my shaking problem: Lower control arm csrumber1 3-Series (E21, E30) 3 09-19-2006 11:02 PM
problem with my engine E 46 M3 M3 SPAIN M-Series (M1, M3, M5, M6) 3 06-27-2006 04:26 PM
Engine Shaking rhyk325i 3-Series (E36) 11 06-25-2004 11:20 PM
shaking problem socalguy 3-Series (E36) 16 06-03-2004 09:27 PM
