E36 ODB2 says Coolant Sensor is bad. - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > BimmerWerkz > New Members Check In
New Members Check In come in say hello...
Old 07-28-2012, 11:37 AM   #1 (permalink)
BillDave121 is on a distinguished road
Hi, I have a 1995 318ic (E36) and the check engine light will not reset. I replaced the coolant sensor and tried to reset light...didn't work. Tried several times. Both old and new coolant sensors respond to temperature changes. Wiring in loom appears to be in good shape. All temperature gauge reading are normal and the car runs fine. My problem is that the car will not pass emissions with the check engine light on. Thanks for any help available, BillDave 121
BillDave121 is offline   Reply With Quote
Old 07-29-2012, 04:13 AM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Have you tried an OBD scanner? Its possible that if the coolant sensor issue is your only problem then you can clear the code and turn off the light. Most auto parts stores have a scanner you can use for free.
Click HERE to see my E36 Blog
Old 07-29-2012, 01:35 PM   #3 (permalink)
Thanks for your reply. Please note title of original post. I am sorry that I did not elaborate on use of OBD2 but i used my Peake unit and also had BMW Dealer used their 10K$ machine to reafirm my reading. In fact, they tried to tell me I needed a new computer ( for max. $). I refuse to accept their analysis since every other function of the car works fine. BillDave121
Coolant sensor M42 Jeremy Wilton 3-Series (E21, E30) 1 02-15-2010 01:19 AM
E34 coolant sensor bimmerholic 5-Series (E12,E28, E34, E39, E60) 2 11-12-2005 07:16 AM
Coolant Leak From Sensor? BMW-ATI 3-Series (E36) 7 06-23-2005 07:41 AM
Damn coolant sensor.... d3ity 5-Series (E12,E28, E34, E39, E60) 1 05-29-2004 08:53 PM
E39 coolant level sensor NC540i 5-Series (E12,E28, E34, E39, E60) 4 05-27-2004 12:56 PM
