engine cut out at 3800 rpm
918 views 2 replies 3 participants last post by  mtccl
#1 ·
I have a 89 325i vert, everything is good until I reach about 3800 rpm's then the engine has a power loss. I have checked the fuel pressure regulator, the full throttle switch and the mass air flow sensor, no luck so far, any ideas on what I should do next
#2 ·
Could be :
coil
camshaft sensor
crankshaft sensor
Im not sure what of the above sensors you have but one controls the injectors and the other the spark.
