NEO Forged Coilover Kits - BMW Forum - BimmerWerkz.com
Go Back   BMW Forum - BimmerWerkz.com > Supporting Vendors > NEO-MOTORSPORT AMERICA INC.
NEO-MOTORSPORT AMERICA INC. NEO-MOTORSPORT AMERICA INC.
Old 01-28-2012, 10:07 AM   #1 (permalink)
Car: 2001 BMW M5
Wei@NEO-Motorsport is on a distinguished road
NEO COILOVER SYSTEM HIGHLIGHTS
NEO Blue
NEO Blue systems was developed to offer a sporty feel and aggressive stance for both aesthetics and daily driving pleasure.
The BLUE features:
• Steel damper construction
• Twin-tube design
• Nitrogen gas insert
• X-Large 25 mm piston diameter
• Ride height adjustable via lower mount
• Spring preload adjustable
• Aluminum alloy shock mounts (forged or extruded depending on application)
• Full-length dust boots
• Fully rebuildable
• 1-year manufacturers defect warranty
NEO Purple
NEO Purple coil-over kit was designed to bring race car level adjustability down to your everyday road vehicle. It features all the advantages of the Blue system while including the shock stiffness adjustability of a Green system. Since our Purple system does not include the pillow ball upper mount, it still offers a higher level of road comfort while capable of aggressive cornering.
The NEO Purple series feature:
• Twin-tube design
• 12 dampening settings
• Massive 30 mm piston diameter
• Spring pre-load adjustable.
• Fully rebuild-able
NEO Green
NEO Green coil-over kit was engineered for improved handling both on and off the track. The shortened shell case allows for maximum piston stroke which translates to a better ride at lower ride height and an increase in grip. The NEO Green systems are also equipped with a pillow ball upper mount. The pillow ball upper mount offers an increase in steering feel as well as upper camber adjustment for strut type vehicles.
The NEO Green series feature:
• Twin-tube design
• Shortened shock body for lowered ride heights
• Camber adjustable via upper mount (on most applications)
• Aluminum alloy shock mounts construction (forged or extruded depending on applications)
Applications for
1992-1998 E36 3-Series
1998-2005 E46 3-Sereis
2005-2012 E90/92 3-Series
2003-2010 E60 5-Sereies
Wei@NEO-Motorsport is offline
Anyone have the Koni coilover kits?? opman1 3-Series (E36) 0 06-01-2009 01:59 PM
H&R Coilover for E46 M3 davidsmithm3 Aftermarket Parts 1 10-26-2005 12:44 PM
HR coilover lowering range asiangear 3-Series (E46, E90) 4 03-27-2004 12:02 PM
