» Sponsors
» Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Member's DIY Projects
Member's DIY Projects Members who have completed and documented their own do it yourself projects.
Old 04-15-2007, 08:57 PM   #1 (permalink)
Retired administrator
triggrhaapi's Avatar
Photos: 0
Frankenmotor Step Three: Camshaft Installation //UPDATE\\
Greetings. It's been a while since my last post, but I've been busy sourcing parts and preparing for the build stage. Several complications have prevented the 2.9l stroker from happening, and instead I am building an S50 from an M50. Don't worry, it's still a frankenmotor to me. Many parts are at my machinist and I am eager to post pictures of the new parts. I drop off the impossible to find last piston tomorrow and I will pick up parts and probably build the motor next weekend.
As for this installment, I will be dropping a pair of S50 camshafts into my camshaft trays and completing the reassembly of the cylinder head. I have replaced all of the valves for cylinder 6, as well as all of the valvestem seals. Sorry I don't have pictures, but I will describe the process:
First you need to remove the valve and the valvespring from the cylinder head as seen here in step one of the frankenmotor build. Then, using a pair of channel lock pliers you squeeze the valvestem seal and twist, releasing and clamping it alternating in 90 degrees so that it deforms and weakens the metal. Be careful not to scar the valve guides as you do this. Once the valvestem seal is off, use a soft cloth to remove any rubber debris from the valve guide and press the new valvestem seal on until it is flush. A barbed lip on the guide holds the seal on by cutting into the rubber against the metal housing. This makes them difficult to get off so do it slowly and carefully. It took Joe (IamJoe) and I nearly two and a half hours to replace the full set.
I have also cleaned, polished, lubricated and reassembled the cup tappets and the camshaft trays. They were kept wrapped in foil until the head was ready to be reassembled, and once the valves and valvestem seals were finished, Joe and I placed the trays inside of the cylinder head. We also put on the VANOS unit and the new valve cover gasket to keep dust out, and just for vanity, added something else...
Also, I have prepared the camshafts by coating the lobes and bearings with assembly lube:
We will be off to the garage in a moment to install the camshafts using the Pelican Parts method. I have tested the theory by placing the camshaft on the cam tray and turning it to find the sweet spot. More pictures will follow detailing our installation. Stay tuned!
Addicted to Speed Since 1997
Old 04-15-2007, 09:01 PM   #2 (permalink)
The Stig
SHAHAB323IS's Avatar
Car: 2009 Civic Si, 1990 Miata
Photos: 0
lookin good
2009 Honda Civic Si
1990 Mazda Miata
Old 04-15-2007, 09:09 PM   #3 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 97 golf, 84 scirocco
Photos: 0
thats great! I like the steps you post here. As far as S50 cams I am still debating on getting them. Are they that aggressive compared to M50 cams, or is it mainly getting the cam software that helps? Granted used S50 cams are wayy less than schricks, or sunbelts.
Old 04-15-2007, 09:15 PM   #4 (permalink)
Photos: 0
The camshafts themselves don't make much of a difference without the software, but yes, they do make a very large difference. The car will have a more aggressive midrange and top end from the S50 camshafts, and will also dump quite a bit more fuel. The major difference in horsepower between the M50 and S50US is the camshafts and fuel injectors. The main difference in torque comes from the extra bore and stroke.
Old 04-15-2007, 09:36 PM   #5 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Photos: 0
I like
Turkey Fleet Bond Holder
Old 04-16-2007, 12:36 AM   #6 (permalink)
Photos: 0
Alright, we're done!! It actually didn't take long once we got downstairs to do it, and our procedure for S50 cams was slightly different from the pelican article, which was written with M50 cams.
This photo shows the correct orientation of the cam as you place it into the cylinder head. In this position, the lobe for cylinder 1 is at an angle, and cylinder 4 is making slight contact with it's respective lifter. This initial angle is only for threading the nuts and is temporary.
After eight quarter turns on each nut, alternating top and bottom after each quarter turn, you can turn the camshaft to the sweet spot where cylinder 1's lobes are straight perpendicular to the cam tray and parallel with the studs that hold the tray in place, cylinder 6's lobe should be straight up and the rest should be all at angles that have no contact. This is the position that your partner will hold while you tighten the nuts onto the studs. I used a torque wrench the whole time (set to 11lbs/ft) so that it would just click when it was torqued. The second angle should look like this:
At this point, the nuts for cylinder 1 should be torqued. Now we put on the nuts for all the other cylinders. Quarter turns are no longer necessary, you can use half turns. Follow the same pattern for tightening these as for tightening the head to the block. Same number of nuts, same need for even pressure. Skip the ones for cylinder 1, since they are already torqued. (duh)
Once that's done, repeat the process until the other side is also done. In this photo, the vanos unit is back on because it's going to seal the front from dust while the head is stored pending my block and bottom end components' return from the machine shop. Keen observers will note a missing nut on E1. This is because my parts guy is a fucktard and gave me an open bag with one missing. I'm going to stop at a local BMW shop tomorrow to get one from a kind mechanic who keeps alot of spares.
To protect against dust, I now put the valve cover on. I will probably drink a beer and celebrate, for not a camshaft did break. Thanks Pelican Parts!
Old 04-16-2007, 01:15 AM   #7 (permalink)
Big Pimpin'
SpeedInfusion's Avatar
Car: ///M3,Corolla
Photos: 0
NICE! i cant wait to do my car next
Old 04-16-2007, 02:32 PM   #8 (permalink)
my car is red
94BMW325i's Avatar
Photos: 0
^what kind of cams are you planning?
Old 04-16-2007, 11:08 PM   #9 (permalink)
willie0915's Avatar
Car: 1995-BMW-M3
Photos: 0
willie0915 is on a distinguished road
look like someone having fun.
willie0915 is offline   Reply With Quote
Old 04-18-2007, 12:24 AM   #10 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
Photos: 0
did you slap a new vanos unit on too? its going to go out soon anyway lol
Kyle Sutherland
"PirateKrautFixieRidinEuroDestroyingRestoring BeerWineScotchRumDrinkingLovingMarriedMan"
M50TU TURNER TREEHOUSE HID LSD KONI BILSTEIN OZ IE ROGUE HELLA MAGNAFLOW MOMO DINAN CORBEAU K&N BLAUPUNKT
gotKRAUT's M50tu Build/Swap Thread
gotKRAUT's E30 Trailer Thread!*Updated 01/30/2010*
Old 04-25-2007, 03:44 PM   #11 (permalink)
DesmoBob's Avatar
Photos: 0
Old 04-25-2007, 03:54 PM   #12 (permalink)
gotKRAUT's Avatar
Photos: 0
LoL love it hahaha ^
Kyle Sutherland
Old 05-01-2007, 02:50 AM   #13 (permalink)
Photos: 0
hahahaha I remember that back in the day!!! Thanks Desmobob! You rule!
Old 05-30-2007, 11:49 AM   #14 (permalink)
Photos: 0
sytl2003 is on a distinguished road
can you tell me what are two numbers that actually shows on the camshafts itself?? because some people said that the S50B30US & M50B25 got the same number on camshafts.
sytl2003 is offline   Reply With Quote
Old 05-30-2007, 01:50 PM   #15 (permalink)
gotKRAUT's Avatar
Photos: 0
that may be the case but the cam profiles are way different i have seen them side by side...
of you are asking if the S50 cams fit in an M50tu the answer is yes....
Kyle Sutherland
vB code is On
How to pull camshaft from head on 88 325ix Slow325i 3-Series (E21, E30) 2 07-13-2006 12:15 AM
