» Sponsors
» Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Member's DIY Projects
Member's DIY Projects Members who have completed and documented their own do it yourself projects.
Old 05-11-2006, 10:34 PM   #1 (permalink)
Retired administrator
triggrhaapi's Avatar
Photos: 0
The Frankenmotor Project: Step Two
Ok, well step two isn't quite finished yet, but I felt like giving you guys an update anyway, just to make you all feel loved. Plus I've got some interesting problems to work out. Anyhow, on with the show:
After the M52's head had been removed (to give it back to it's owner) I discovered a bunch of rust in the cylinders. Now any other person but me would commit hara kari when seeing what I'm about to show you, but I'm strong, what can I say.
This one is cylinder #1, there's a hair of corrosion there, not so bad.
This is cylinder #2, which is identical to cylinder #6, absolutely zero corrosion.
Here's where the nightmare begins. You are looking at cylinder #4 just at the bottom of the image you can see a little ring of corrosion on #3, but #4 and #5 are pretty much both the same. Bad. very very bad. Thankfully the corrosion isn't so bad that I need to bore out the block, it just needs to be honed. That can be done by hand with a special tool that attatches to a drill and is specially designed not to take any metal with it, just the corrosion.
I'll post some pics of that when I get around to doing it. Also you can clearly see that I'm gonna be spending alot of time with a wire brush and a dremel cleaning out all of the passages that have gotten corroded, as well as all of the corrosion on the block itself. I'll post up pics of that when I get around to doing it.
Here's a shot of Piston #1, you can see clearly where the exhaust valve smacked the piston if you look closely, or you can cheat and look at where the arrow I provided is pointing.
Here is a side by side comparison of the M52 rods (left) versus the M50 non-vanos rods (right). Believe it or not, the M50 rods are quite a bit lighter than the M52 counterparts and are also visibly quite beefier. The M52 rods are made using the cracked cap method rather than having a rod and cap that are cast seperately. The cracked cap method is cheaper to manufacture, probably why it showed up on the 323 engine (sorry shahab).
This closeup shows the retention ring that holds the wristpin in place. I just stuck a pair of needlenoses in there and pulled it out. Getting it back in is harder, but I did it one half of the ring at a time and that worked well. there may be a special tool to do this, but fuck if I'm patient enough to find it.
Well that's it for now, I'll update this thread once I've honed out the cylinders and I'm ready for reassembly. In the mean time, the conrods and pistons are off to the machine shop to get balanced.
Addicted to Speed Since 1997
Old 05-11-2006, 11:19 PM   #2 (permalink)
Canadian
Furious's Avatar
Photos: 0
good stuff dude. im suprised how much corrosion is in those cylinders. but all in all the most suprising thing is the comparison of the non vanos rod
R.I.P Steve aka fast 6
Old 05-11-2006, 11:37 PM   #3 (permalink)
Photos: 0
The M52B25 rods fucking suck.
Old 05-16-2006, 02:59 PM   #4 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
Photos: 0
man those M52 conrods are complete trash lol...i feel bad for all you M52 folks, if you are reading this and have a M52, and need a rebuild soon, throw those away!!!!!!!!!
Kyle Sutherland
"PirateKrautFixieRidinEuroDestroyingRestoring BeerWineScotchRumDrinkingLovingMarriedMan"
M50TU TURNER TREEHOUSE HID LSD KONI BILSTEIN OZ IE ROGUE HELLA MAGNAFLOW MOMO DINAN CORBEAU K&N BLAUPUNKT
gotKRAUT's M50tu Build/Swap Thread
gotKRAUT's E30 Trailer Thread!*Updated 01/30/2010*
Old 05-16-2006, 03:28 PM   #5 (permalink)
For Teh Walrus?
WALSRU's Avatar
Car: 1980 635csi euro
Photos: 0
WALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to behold
Send a message via AIM to WALSRU Send a message via MSN to WALSRU
Well I certainly didn't know that either. Ya know, without you guys I would've never known how good non-vanos can be.
"I would not know what the spirit of a philosopher might wish more to be than a good dancer."
- Friedrich Nietzsche
1980 635csi Euro . . . Current
1985 535i . . . Soon to be parted out
2001 Subaru Forester . . . DD
WALSRU is offline   Reply With Quote
Old 05-17-2006, 02:10 AM   #6 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 1
Any input on m52b28 rods?
Old 05-17-2006, 03:15 AM   #7 (permalink)
Photos: 0
no idea, haven't seen them. I would hope they would be much better, but I highly doubt it.
Old 05-17-2006, 02:35 PM   #8 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Photos: 0
Turkey Fleet Bond Holder
Old 05-17-2006, 10:13 PM   #9 (permalink)
Photos: 0
well given how they cheaped out on the 323 motor, it would make sense that they may cheap out on the 328 motor as well. Maybe not though. The rod length is the same as what I'm using.
Essentially from what I can tell, the M54 was built based on the S52 crankshaft used to stroke out the narrower bore M52b28 to make 2979cc displacement. I'm working with a slightly different formula, which is S52 crank and M50 non vanos rods (same length and were cheaper, and possibly beefier, don't know about that) with M52B25 pistons that have been decked to a height to produce an 11.5:1 compression ratio (or thereabouts), as opposed to the M54 pistons which are slightly shorter than the 328 pistons, but end up producing the same compression ratio of 10.2:1.
I'm going to run off of a turner chip for an E36 M3 using an E36 M3 cylinder head and camshafts, and using a set of Ireland Engineering headers on an E36 M3 midpipe with a stock E36 M3 exhaust. All in all, it ought to resemble an S52 that's been OBD I converted in terms of power output, so around 235whp, depending on how much difference 200cc makes versus how much difference 11.5:1 makes. Let's say between 230whp and 250whp.
Old 05-19-2006, 02:52 PM   #10 (permalink)
gotKRAUT's Avatar
Photos: 0
Now thats what im talking about...those are some impressive NA numbers
Kyle Sutherland
Old 05-22-2006, 11:52 AM   #11 (permalink)
Live Fast. Drive Faster.
buuhh99's Avatar
Photos: 0
buuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond repute
Send a message via AIM to buuhh99
so how much do u think u will be making a the crank?? around 290??? How would corrosion get in there??? Do i need to worry about that
buuhh99 is offline   Reply With Quote
Old 11-13-2006, 11:58 PM   #12 (permalink)
theruss1an1's Avatar
Car: Needs momentum
Photos: 0
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
You have a PM.
-Serge
theruss1an1 is offline   Reply With Quote
vB code is On
Step Tronic:Good,bad Why? Maximusmace 3-Series (E36) 28 05-29-2006 12:42 PM
Blacked Out Grills And Roundels BLACKBMW 3-Series (E36) 5 11-10-2004 12:35 PM
Mammoth e36 DIY El Presidente Audio and Electronics 0 06-24-2004 01:02 AM
