Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Member's DIY Projects
Member's DIY Projects Members who have completed and documented their own do it yourself projects.
Old 11-07-2007, 11:07 PM   #1 (permalink)
zr3
zr3's Avatar
Photos: 0
zr3 is on a distinguished road
Painting Tips
i,m painting the z as most of you know , ive painted more cars then i can remember , anyone want me post some steps and pics ???
zr3 is offline   Reply With Quote
Old 11-07-2007, 11:12 PM   #2 (permalink)
Teh whore
AlpineSixAndSeven's Avatar
Car: 1986 325es, 1987 635CSi, 1976 Benz
Photos: 0
Please do...
Originally Posted by drz View Post
I'll never be bound to no man by means of a piece of paper
Old 11-07-2007, 11:32 PM   #3 (permalink)
zr3
zr3's Avatar
Photos: 0
alright , i ,m just going to ramble and post as think of stuff that might help , feel free to argue with me , but everyone has their own tricks and techniques so if i,m doing something a way you don't like ... tuff , i,m just posting what ive been doing for many years , and i don't claim to know it all or even close .
Old 11-07-2007, 11:40 PM   #4 (permalink)
zr3
zr3's Avatar
Photos: 0
one thing ive learned the hard way is paint shrink !! it looks great and then a month later the paint cures in the sun and you start to see all the sand scratches , some body shops in buss for many years still dont know what they are doing wrong , the secret ??? stay away from lacquer based primers , yes they are easy to sand , but they also shrink the most later on , i now use 2 part primer surfacers . next . guide coat , guide coat as seen in the pic is used to find low and high spots BEFORE you paint and see all the flaws . spray it on light or heavy and then block sand in a crisscross motion , see the dark spots ??? they are low spots and would appeared wavy once painted , this part of my car was never damaged to my knowlage and when it was black i really didnt see it , but i want to look as good as it can so i will block this until its perfect . more later
ID:	26102  painting-tips-pics-112007-112-small-.jpg.jpg
Old 11-09-2007, 10:43 AM   #5 (permalink)
zr3
zr3's Avatar
Photos: 0
to keep my sand paper from clogging up too much , i take a paint stick and smack the sand paper every few min of sanding , this keeps it clean and keeps it works as i sand , sand paper and everything else is expensive now a days so this keeps it lasting as long as it can . ( see pics )
Old 11-10-2007, 03:24 PM   #6 (permalink)
zr3
zr3's Avatar
Photos: 0
#1 for areas that are rounded and compound curved i use a heater hose , left over from other repairs it conforms well to many areas ( see pic ) , #2 also to mask off tires i use large garbage bags , but keep in mind this is primering only , make sure to not have plastic where you are final coating , after one dry coat of paint on plastic it can dry and then flutter from the air of a paint gun and come loose and then into the next coat of new paint , ( see pic ) use paper or a old blanket to cover the plastic bag .
ID:	26108  painting-tips-pics-112007-144-medium-.jpg.jpg
Old 11-10-2007, 03:31 PM   #7 (permalink)
zr3
zr3's Avatar
Photos: 0
# 1 if you live in an area where its cold you need to know the true temp of what your working on or painting , it may feel warm in the garage but the true temp of your paint and the metal can be much different and effect dry times and so on , i use a non contact temp meter ( see pic ) there are better ones out there but i,m still using this one i bought for about 20 bucks . this is one of the many items that is critical to know and correct if its too cold . you can also use a heat lamp or infared lamp to help dry areas if needed .
Old 11-13-2007, 11:55 PM   #8 (permalink)
zr3
zr3's Avatar
Photos: 0
painted but far from done
painted !!! but now its on to wet sanding and more paint and clear
ID:	26113  painting-tips-img_0895-medium-.jpg.jpg
Old 11-14-2007, 12:00 AM   #9 (permalink)
zr3
zr3's Avatar
Photos: 0
it looks good again !!! now its time to make it look like crap again ( wet sanding )
RUNS !!! i had a run at the door handle , i guess i shot too much clear in there making sure i got clear up behind it , i take a new razor blade and at a 90 degree angle ( straight up ) i shave the run off untill its flat , then wet sand over it all , see pics .
ID:	26115  painting-tips-img_0905-small-.jpg.jpg
ID:	26116  painting-tips-img_0906-small-.jpg.jpg
Old 11-14-2007, 12:04 AM   #10 (permalink)
zr3
zr3's Avatar
Photos: 0
i always ground my cars , i got lucky and i have a pipe running into the ground inside my garage , but its important to do this as it keeps down the static electricity and doing anything to keep down the dust in the paint will help , even in a paint booth some guys do this .
Old 11-14-2007, 10:55 AM   #11 (permalink)
teh lifesaver
german-speed-demon's Avatar
Car: a japanese econobox
Photos: 3
Send a message via AIM to german-speed-demon Send a message via Yahoo to german-speed-demon
Also, warm paint flows better. I use a heating plate for about 5 minutes prior to spraying to warm the paint up to about 65 degrees.
R.I.P fast 6
Old 11-14-2007, 05:17 PM   #12 (permalink)
zr3
zr3's Avatar
Photos: 0
not a bad idea , ive been keeping my paint inside so its room temp and i dont bring it out until i need it , but i just make sure my temp of the car and shop are warm as well .
Old 11-14-2007, 09:36 PM   #13 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 97 vw golf
Photos: 0
great info so far! How about painting a plastic piece, specifically the trunk latch cover. The piece that goes over the trunk release button and covers up where the license plate lights are? I would be using a can of spray paint.
Old 11-16-2007, 10:38 PM   #14 (permalink)
zr3
zr3's Avatar
Photos: 0
i dont know exactly what part it is , but i used to work in a paint shop for GM and all the plastic parts came in black an we would paint them to the color of the car or truck , you need to find a can of plastic prep , its primer for plastic and then get paint for plastic , ( its normally lacquer based ) and paint away , let it dry over night and dont wax for at least a few weeks
Old 09-28-2008, 11:42 PM   #15 (permalink)
Photos: 0
anglejolie is on a distinguished road
painting tips
Speaking of oil-based paint, if the previous painter was foolish enough to use it, you must prime everything first, for latex paint will not stick to oil.
angle
Car Auctions
anglejolie is offline   Reply With Quote
vB code is On
New Bmw Genuine Chrome Exhaust Tips E46 323/325 Boomstrike Classifieds Sell & Buy 0 12-01-2004 09:30 PM
Painting tips?? B3M2W5i 3-Series (E36) 2 07-07-2004 11:51 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
