Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > Member's DIY Projects
Member's DIY Projects Members who have completed and documented their own do it yourself projects.
Old 05-06-2007, 03:37 AM   #1 (permalink)
Stealth Expert
triggrhaapi's Avatar
Photos: 0
Frankenmotor Step Five: Engine Assembly!!
Here comes the big payoff!!! Sorry I don't have pictures of the ringing and wristpin install process, or the piston install, but I wasn't in charge of the camera this time.
Here's how it went: I had to install the rings by hand after alot of swearing when the ring install tool turned out not to be working. We also had a stupid non functional ring compressor tool, so I ended up borrowing one from Joe's dad. It was made some time in the BC era, back when man first discovered steel. It also worked beautifully and thankfully is still in good condition for it's stint at the Smithsonian Pre-History exhibit.
Here's the results after praying to a demon god and summoning a photographer, who just so happened to be Joe's Dad, who also brought the ring compressor:
Tada!!!! Good eh?
Guinness is the official beer of this build. Bottle dates back to original thread.
Here it is from the bottom. Torque specs for the rod bolts are as follows: 20nm, torque to 50 degree torque angle, same as the mains. Bolts must be oiled and brand new for install, as they are torque to yield.
Head gasket goes on and we torque down the head bolts. They are also brand new as they are torque to yield. Torque to 30nm in sequence per the Bentley manual, then again to 90 degrees, then 90 degrees more.
Head is installed. Now we hook up the timing chain to the exhaust cam.
Unfortunately the chain had a snag that needed some fixing so we had to remove the timing cover, and turn the crank about 5 degrees to slip the kink off of the teeth on the crank. We then turned the crank back. At this point I thanked god that I didn't torque down the big bolt on the crank, and only had it on somewhat hand tight.
Kink fixed!!!
The cam timing was already set to TDC I just wanted to show what the tool looks like. I guess I'm gay like that.
Random porn shot.
Addicted to Speed Since 1997
Old 05-06-2007, 05:13 AM   #2 (permalink)
iamjoe's Avatar
Location: The collected thoughts of a subconcious psyche trippin' on acid and THC. Chill as I take you on a tr
Photos: 0
iamjoe is on a distinguished road
Send a message via ICQ to iamjoe Send a message via AIM to iamjoe Send a message via MSN to iamjoe Send a message via Yahoo to iamjoe
I'm allergic to stupidity. If exposed, I may begin to insult the cause repeatedly.
The liver is evil, it must be punished!
The Great and Ganjaful Pyrolah of the Secret Brotherhood of the Huzzah
iamjoe is offline   Reply With Quote
Old 05-06-2007, 06:27 AM   #3 (permalink)
Fixie Ridin Administrator
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
"very niice, how much?" -Borat
lookin hawt, btw i know you are an attention whore and all, but seriously, couldnt you combine these into one project thread? lol
fine ok, maybe just once you are done them combine it into one project thread
Kyle
"PirateKrautFixieRidinEuroDestroyingRestoring BeerWineScotchRumDrinkingLovingMarriedMan"
M50TU TREEHOUSE HID LSD KONI BILSTEIN OZ IE ROGUE HELLA MAGNAFLOW MOMO DINAN CORBEAU K&N BLAUPUNKT
gotKRAUT's M50tu Build/Swap Thread *Updated on Thursday 10/09/08*
CarDomain Page
Old 05-06-2007, 11:36 AM   #4 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit
Photos: 0
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
Should have a project sub-forum.
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 05-06-2007, 02:15 PM   #5 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
When does it go into the car?
1995 E38 740iL. Highly modded. Faster than you.
Lindsay fan club member.
Old 05-06-2007, 05:10 PM   #6 (permalink)
Stealth Expert
Photos: 0
Tomorrow most likely. I'll have one more update soon where I set the cam timing /install the VANOS unit permanently and put the oil pan on. That's all that's left on the motor build. Then the clutch and trans go on and it gets dropped into the car.
Old 05-06-2007, 06:44 PM   #7 (permalink)
drz
master of his domain
drz's Avatar
Car: e36 2.8i; e46 zhp
Photos: 0
mad tyte yo
Turkey Fleet Bond Holder
drz is online now   Reply With Quote
Old 05-06-2007, 07:20 PM   #8 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
Photos: 5
We do have one. http://www.bimmerwerkz.com/forum/upgrades-performance/
No one uses it...
My BMW Blog
Old 05-06-2007, 07:49 PM   #9 (permalink)
Stealth Expert
Photos: 0
I'm probably going to archive this to that forum after the project is over. I'll just combine all the threads into one.
Old 05-06-2007, 09:30 PM   #10 (permalink)
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
Originally Posted by ldsbeaker
its because it is a subforum, make the project thread in the main forums page and it will get some damn use, hell i will even use it!!!!!!!
trigg love the sig, bout time you made one lol
Kyle
CarDomain Page
Old 05-07-2007, 05:36 AM   #11 (permalink)
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
+1 I didnt even know it was there.. sub forums ftl.. I never goto the help section as, well, who am *I* to ever need help?
When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko
Old 05-28-2007, 02:48 PM   #12 (permalink)
Car: 92 325is - E34 -E30
Photos: 0
R_F_L is on a distinguished road
That's pretty awesome man!
R_F_L is offline   Reply With Quote
Old 06-09-2007, 08:51 PM   #13 (permalink)
uber e36's Avatar
Photos: 0
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
Sad the 2.9L didn't work out, but glad to see you're having fun.
I have one criticism which may be premature... Why have you not cleaned your valve cover?
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Old 06-10-2007, 01:28 AM   #14 (permalink)
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
its not dirty, its chipped, hes waiting untill its all inside and working then he will pull it off and have it painted/powdercoated, no point making it pretty then chip it all up on install
Kyle
CarDomain Page
Old 06-19-2007, 12:02 AM   #15 (permalink)
Photos: 0
dave_21 is on a distinguished road
i need help on how to repair my regulator on bmw328i on my passenger side window so if u or ne one knws plz send me a mail thankx really need help asap
dave_21 is offline   Reply With Quote
vB code is On
