Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Go Back   BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > M-Series (M3, M5, M6)
M-Series (M3, M5, M6) General M-Series Discussion - If it does not fit into a more specific M Category above, please place it in here. In addition, previously archived M-Series discussion is located in this section.
Old 09-11-2004, 06:50 AM   #1 (permalink)
Photos: 0
34022DR is an unknown quantity at this point
I own a 1999 BMW M3 which I purchased last Nov. '03. It has Goodyear Eagle F1 tires mounted. The right rear tire rumbles, especially when starting to drive and the rubber is still cold. The mechenic I use and trust for my basic maintanance says the tire is "scalped" or somthing like that. He recomends that I have the suspension checked befor considering new tires.
Has anyone encountered this problem or have any thoughts?
34022DR is offline   Reply With Quote
Old 09-17-2004, 11:54 PM   #2 (permalink)
97alpineM3's Avatar
Car: Blah
Photos: 0
97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light
Yes... its maybe one of three things... it is natural for e36 Ms to wear a little bit faster on the rear right tire due to the limited slip diff... its not a very tight diff back there.. but it enough to notice if you absolutly work the car on a regular basis... another reason for the wear on that tire might be your rear tailing arm bushing.. might be born causing the tires to angle in a direction that promotes wear.
Is the inside of the tire wear faster?... if so.. you have camber problems... if it is very extensive... you can purchase adjustable camber arms to control the camber on the tires back there.. and prevent the excesive wear.
BTW.. its a good rule of thumb.. to maybe ever 3 months look under the car.. and inspect your bushings... every single one of them.. and make sure they have no signs of deterioration... the slightest wear can cause a bushing to fail.. causing more problems... often you cant tell if a bushing is fully failed untill you have taken it apart from the arm.... just do a good inspection.
Good Luck
Les
1997 E36 M3 1990 E30 325i
Old 09-22-2004, 09:59 PM   #3 (permalink)
KingScare's Avatar
Photos: 0
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
Damn...thank you.
KingScare is offline   Reply With Quote
vB code is On
325i Tire Question Ii fobbie 3-Series (E46, E90) 0 03-26-2005 09:09 PM
Tire Question dtinsman75 3-Series (E46, E90) 1 01-10-2005 01:53 PM
New Tire Needed Turbodefrost 3-Series (E36) 5 10-10-2004 06:26 PM
WHEEL and TIRE Question JL380 3-Series (E36) 1 02-05-2004 10:36 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
