Winter Tire Setup For 2001-2004 M3? - BMW Forum - BimmerWerkz.com
Old 11-08-2004, 09:28 PM   #1 (permalink)
Nominee is an unknown quantity at this point
Hi all,
I need to purchase a set of winter tires and wheels for my car and I was hoping I could get some feedback.
1. Can I use a 16" rim? If so, what size and offset?
2. What tire sizes can I use with the 16" rim?
3. If I have to use a 17" rim, what size and offset do I require?
4. What tires sizes can I use with the 17" rim?
5. Do I have to maintain a staggered tire setup for winter?
I would appreciate your personal setups as well.
Thanks for your time.
Nominee is offline   Reply With Quote
Old 11-09-2004, 09:40 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Go to www.tirerack.com
They have really good write ups on most of what you need to know about winter driving... and the right tires for you...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 11-09-2004, 01:21 PM   #3 (permalink)
Good Luck,
Les
[snapback]227407[/snapback]
Thanks, but I tried there, and all they list is an 18" tire setup. It does not give alternate options and rim sizes/offset.
Old 11-09-2004, 03:48 PM   #4 (permalink)
Trevize's Avatar
Trevize will become famous soon enoughTrevize will become famous soon enough
Send a message via AIM to Trevize
See if this works:
http://www.tirerack.com/snow/WinterTireCom...e&performance=W
Seems 17in is the smallest rim size recommended by tire rack. Prolly because of break clearance.
Trevize is offline   Reply With Quote
Old 11-09-2004, 09:40 PM   #5 (permalink)
Originally posted by Trevize@Nov 9 2004, 05:48 PM
See if this works:
[snapback]227573[/snapback]
Size:225/50-17 for all 4 tires? Don't we have to maintain a staggered setup?
Also, it doesn't list rim width and offset.
Old 11-10-2004, 04:39 PM   #6 (permalink)
Trevize's Avatar
Originally posted by Nominee+Nov 9 2004, 10:40 PM--><div class='quotetop'>QUOTE(Nominee @ Nov 9 2004, 10:40 PM)</div><div class='quotemain'><!--QuoteBegin-Trevize@Nov 9 2004, 05:48 PM
See if this works:
[snapback]227834[/snapback]
[/b][/quote]
No you don't *have* to maintain it. Sure it performs better on dry summer pavement that way. All depends in what type of weather you expect to drive in for the winter. Is it rain? Snow? Lots of snow? etc.
I'm in the situation where I drive an M5 in winter I basically have to suck in my pride and actually have "winter" tires. I have them mounted on 4 identical rims. Ya it sucks as I hate the way it looks and dry pavement performace suffers. I feel like I could be accused of driving a "fake" M5. But when the snow falls and it falls a lot at the base of the ski resort I live under I have no problems getting around. So laugh at me now in my snow tires on an M5 as I pass you going up this mountain! HA HA! It doesn't stop me from dreaming of Spring when I can put the summer tires and rims back on and re-claim my performance tires and that agressive stance on the road look with the wider in the rear rims/tires gives the M cars.
You have the make the choice for where you live and what you intend to drive your car through. You can get all season tires for your current rim size. They will suck in snow but do well in everything else. Or you can get snow/winter tires that will be a dream in snow, do well in rain and make you cry on dry pavement.
Old 11-10-2004, 08:17 PM   #7 (permalink)
Originally posted by Trevize+Nov 10 2004, 06:39 PM--><div class='quotetop'>QUOTE(Trevize @ Nov 10 2004, 06:39 PM)</div><div class='quotemain'>
See if this works:
Seems 17in is the smallest rim size recommended by tire rack.* Prolly because of break clearance.
[snapback]228244[/snapback]
[/b][/quote]
I live in Toronto, Canada. Sometimes (rarely) we can get a fair bit of snow. I was worried about the staggered setup due to the fact that it can throw off our traction control systems. Due to the different rolling diameters of having a staggered setup.
Old 11-20-2004, 05:27 AM   #8 (permalink)
frw73's Avatar
frw73 is an unknown quantity at this point
Re: Staggered Setup.
Note that if you run fat tires on dry pavement, this is a good thing. However, if you run them in the snow, you'll 'float' on it. The idea is to reduce tire width to distribute the car's weight over a smaller area.
So, get winter tires if you plan to do this, and don't stagger if you can help it, otherwise you'll be doing donuts on the highway.
(Or, store the car
Oh, and Nominee, from one fellow Torontonian to another, make sure that if you decide to run your ///M in the winter, that you should watch the front air dam clearance. This is around six inches (please see my numerous posts on this), and if the snow ices over, you'll turf it, especially if you go to 17's and don't run a higher sidewall.
<img src='http://www.bmw-forums.com/forum/uploads/post-11-1087193660.jpg' border='0' alt='user posted image' />
frw73 is offline   Reply With Quote
Old 11-20-2004, 11:08 PM   #9 (permalink)
(Or, store the car
[snapback]234235[/snapback]
Thanks...I've been storing the car for the past 2 winters, but was thinking about driving it through this winter. But, now I've decided to store it again! I bought a 350Z 2005, and I didn't want to store both cars. So now, I have to buy a beater!
Interesting Tire Setup Live_the_Curves 3-Series (E36) 4 11-21-2004 01:58 PM
My 2004 BMW 530i.. problems with a new car. SurfCityJohn 5-Series (E12,E28, E34, E39, E60) 7 09-02-2004 10:40 AM
Turbo can I put into my car? flipsgonetopless 3-Series (E21, E30) 17 03-30-2004 04:29 AM
330xi winter wheel and tire size ///MONSTER 3-Series (E46, E90) 4 10-13-2003 08:45 PM
