used 95 m3 - BMW Forum - BimmerWerkz.com
Old 12-27-2003, 07:03 PM   #1 (permalink)
socalguy is an unknown quantity at this point
i am looking into getting a e36 m3. I recently found a 95. What are the important things to ask the owner? it has 72,000. how long can a well taken care of engine last?
And i recall reading about 2 things that needed to be changed on the 95 but dont remember what they were...
Any help would be greatly appreciated!
socalguy is offline   Reply With Quote
Old 12-28-2003, 01:16 PM   #2 (permalink)
cam540 is an unknown quantity at this point
make sure the car has been properly maintaned and the owner has the records. The engine is just being broke in at 72k miles if the guy took care of the car.
You'll need to change the plastic impeller from the water pump to the metal one if it hasn't been done
<img src='http://people.albion.edu/dbc10/images/w04.gif' border='0' alt='user posted image' />
<a href='http://http://www.licenseschoolusa.com/real-estate-book.php' target='_blank'>Real Estate Books</a> | <a href='http://www.spotya.com' target='_blank'>Spotya! Quick Cash</a> - Short term cash loans for online shopping.
<a href='http://www.licenseschoolusa.com' target='_blank'>Real Estate License</a> | <a href='https://www.linkedin.com/profile?viewProfile=&key=1629532' target='_blank'>My LinkedIn Profile</a> - Contact me
cam540 is offline   Reply With Quote
Old 01-02-2004, 05:31 PM   #3 (permalink)
M3pow is an unknown quantity at this point
Are the 1995 M3 E36 high maintenance cars?
M3pow is offline   Reply With Quote
Old 01-03-2004, 05:31 PM   #4 (permalink)
thanks for the information. it will help me a lot.
Old 01-05-2004, 09:59 AM   #5 (permalink)
KingScare's Avatar
Car: 98 M3
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
Is there a way to tell if the water pump was replaced (well the defective part) or what not...
my M3 just tipped over 50 000 k , I could check up in the maintenance records, i remember the dude saying he did change it sometime.
But is there a way to check it DIY style?
KingScare is offline   Reply With Quote
Old 01-05-2004, 01:52 PM   #6 (permalink)
DesmoBob's Avatar
the only way to tell is to pull it out and look at it.
the impellers on the old plastic ones are tan or orange in color.
for a short time bmw upgraded to stainless steel (good).
then they upgraded again to a higher quality synthetic composite (good). these are the ones that are currently available.
there are aftermarket ones which are metal, but are cast iron (bad). i have a brand-new in-the-box never used metal cast iron one (Graf) which i will sell on e-bay because i have decided to go with the newer composite impeller.
read this for more info:
http://www.bimmerforums.com/forum/showthre...p?postid=931023
the cheapest place i have found for a water pump is http://www.eap4parts.com
($67.95 for new OE composite, $41.95 for the Graf cast iron)
