turbo m50 - BMW Forum - BimmerWerkz.com
Old 12-05-2003, 02:42 AM   #1 (permalink)
Bayerische Motorenwerke is an unknown quantity at this point
I am considering purchasing an m coupe (not considering, just waiting for more money), and I want to purchase a mechtech motorsports turbo. One example has made 300 wheel horsepower and apparantly others have seen higher numbers. 300 whp was achieved at 8 psi. How much boost in psi can the 3.2L m50 take regularily before a built bottom end is necessary?
Bayerische Motorenwerke is offline   Reply With Quote
Old 12-05-2003, 06:19 AM   #2 (permalink)
the///man is an unknown quantity at this point
this one will get you to 430hp! its expensive as hell but that would be sooo fast
sry, i didnt exactly answer your question but its related to your topic so i thought i would throw that out there
the///man is offline   Reply With Quote
Old 12-06-2003, 11:04 AM   #3 (permalink)
True, the aa kit is a beast, but you saw how expensive it is. The mechtech kit is 5000 dollars, as opposed to 30 000 with installation. The mechtech kit makes a heavy 300 at the wheels at 8 psi, and I need to know how high I would be able to turn up the boost without damaging or stressing the engine. If I could dial in 12+ psi I would be doing about 340-350+ horsepower at the wheels without additional mods (or few). I just don't know if the stock bottom end can hanbdle it. Anyone else got a clue?
Old 12-07-2003, 09:35 AM   #4 (permalink)
Fissionx's Avatar
Fissionx is an unknown quantity at this point
pretty strong, it'll be safe if you have enough fuel, spark, compression, and a turbo capable of operating efficently in w/e pressure range you want. There are a couple of people running close to 20psi w/ a full t61 on stock bottom end and are having no problems.
-Dan
Turbo 328
<img src="http://www.bmw-forums.com/forum/inde...2858">
Fissionx is offline   Reply With Quote
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
Custom M3 Turbo Vs Aa Turbo M3 NyteRyda Video Vault 3 04-23-2005 09:20 PM
