Trouble With My 1998 M3 - BMW Forum - BimmerWerkz.com
Old 02-17-2005, 10:20 AM   #1 (permalink)
Need-4-Speed is an unknown quantity at this point
Back in January, cylinder #6 in my 1998 M3 stopped functioning and the Check Engine light came on. Further inspection revealed a melted coil. I replaced the coil and the problem persisted, melting another coil. Unable to figure out what was wrong, I took the car to my local BMW shop (not a dealer) and here's what they did:
Replaced coil and injector. Did not cure the problem.
Checked the wiring harness. Found nothing wrong.
Replaced the ECM and this cured the problem for about 5 days, at which time, the problem returned.
Does anyone out there have any idea what could be wrong? I've spent $500 in diagnostics with this guy, who is not fixing the problem. (The rest was covered my warranty) I want to be sure he is not just stringing me along.
Thanks to anyone who can shed some light on this.
Need-4-Speed is offline   Reply With Quote
Old 02-17-2005, 11:36 PM   #2 (permalink)
something like this should be seen by the dealership.
Old 02-21-2005, 08:52 AM   #3 (permalink)
The dealership put in another brand-new ECM and so far the car is running fine. What are the odds of 2 of those things going bad within 1 month?
Old 02-21-2005, 08:20 PM   #4 (permalink)
POWER///M is an unknown quantity at this point
Test your distributor.
POWER///M is offline   Reply With Quote
Old 02-22-2005, 02:13 PM   #5 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
i may be wrong, but he has coils, which means no distributor , right?
xsperf is offline   Reply With Quote
Help Buying 98 M3 spy4652452 M-Series (M1, M3, M5, M6) 6 02-13-2005 06:27 PM
Carfax Please: Wbadd632xwbw44671 cpuken 5-Series (E12,E28, E34, E39, E60) 3 12-03-2004 08:04 PM
1998 E39 525tds Manual Gearbox/clutch Trouble demc7 5-Series (E12,E28, E34, E39, E60) 1 11-11-2004 11:42 AM
