Synthetic vs Petroleum oils - BMW Forum - BimmerWerkz.com
Old 02-12-2008, 06:42 PM   #1 (permalink)
mnichols is an unknown quantity at this point
I just purchased a 1995 M3 to make into a track car. It.s in the hands of a trusted mechanic who drives a Ferarri, Benz and several BMWs. We got into a discussion about engine oil, and his personal experience on changing from petroleum based oil to synthetic. On his 90s vintage cars he often developed leaks in valve cover and other gasket sealed devices shortly after switching to synthetic. Has anyone had similar problems? I'm about to change the oil in my 95 M3 for the first time, I'm not sure if the past owner used petroleum or synthetic and I'm about to use synthetic.
mnichols is offline   Reply With Quote
Old 02-12-2008, 06:47 PM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
the reason these leaks appear is that synthetic often cleans out your oil passages in your engine. The petroleum based oils create buildups in certain parts and as they age actually can stop up any leaks that would appear otherwards. The way i look at it use synthetic. If a leak occurs replace the gasket as there should have been a leak there anyways but you had oil gunk clogging it up.
Old 02-12-2008, 10:29 PM   #3 (permalink)
Linds's Avatar
Linds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond repute
Send a message via AIM to Linds
^Exactly. I switched to synthetic when I got my car and the valve gaskets did start to leak, but they're really easy to replace.
Coming soon...
Linds is offline   Reply With Quote
Switching OILS MEDSTUDENT87 5-Series (E12,E28, E34, E39, E60) 5 01-05-2010 02:29 AM
Theories for successful synthetic oil use in E36 frenchtoast 3-Series (E36) 9 03-26-2007 11:29 PM
what type of oil should i use? jheabs 3-Series (E21, E30) 10 11-22-2006 10:21 PM
Full Synthetic Oils zibby 3-Series (E46, E90) 4 03-25-2005 12:59 PM
Synthetic or regular oil? am4tide 3-Series (E36) 6 07-14-2004 08:03 AM
