Stroking an S50B30 95 M3 motor - BMW Forum - BimmerWerkz.com
Old 10-01-2005, 10:21 PM   #1 (permalink)
BMWjesterFAN's Avatar
BMWjesterFAN is an unknown quantity at this point
Anyone know where I can find info on stroking a 3.0 S50 engine? I'm looking to make some decent power NA, and then possibly go with a supercharger, but I don't want to be like everyone else and just throw a Vortech on it and call it a day. I am tearing the motor down now, and will have the head ported, polished, and decked, and a valve job done, along with the block being acid dipped and both being inspected. Where should I go from there? Keep in mind that I am not rich, and will do as much of the work as I can myself. I rebuild internal combustion engines on aircraft in the Air Force, so I think I can handle the assembly stuff, and some minor engine work. Thanks,
-Tim
BMWjesterFAN is offline   Reply With Quote
Old 10-08-2005, 10:56 PM   #2 (permalink)
I have a new idea. Well, not new, just modified. According to BMW factory specs, I can overbore the block from my S50 to take S52 piston sizes. I could then us an S52 crank and Wiseco forged S52 pistons. In particular, they have a set of 13:1 compression pistons. Stroked and bored to basically a 3.2, plus the 13:1 pistons, OBD1 harness from my S50, head work (port, polish, valve job, decked), maybe some sunbelt cams (heard they are a bit more aggressive than schrick), underdrive pulleys (have 'em from Turner MS already). What do you guys think? I know I would have to run high octane gas, but any ideas on how much power I may be able to make? Oh, and since I am going to Korea for a year, I will be saving up for the TEC3, AEM, or another stand-alone EMS. Opinions? Help? Naysayers?
-Tim
Old 10-10-2005, 04:54 PM   #3 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Sounds expensive.
Old 10-10-2005, 06:35 PM   #4 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
13 to 1 compression? sounds a bit high. You will DEFINITELY need to run high octane fuel. If you're going to put the s/c on, you might as well keep the compression down to a reasonable level. Otherwise, you're acid treated block and gold plated components will go boom.
My BMW Blog
Old 10-11-2005, 11:02 PM   #5 (permalink)
Well, I would definitely run really high octane, probably race gas. And this would be for NA power. I would drop in some stock or dished pistons when I slap the blower on. Already got the machine shop lined up for the work, just need to get a good set of pistons so they can bore and hone the cylinders to match the individual pistons.
Blower Motor Chirp Fixed jnash 3-Series (E46, E90) 2 07-07-2009 09:41 AM
Stroking a 95 M3 S50B30 engine and other mods BMWjesterFAN 3-Series (E36) 6 10-04-2005 02:54 AM
Lost 2 Blades On The Motor Fan just_program 3-Series (E36) 11 11-27-2004 10:07 PM
