Secondary Air Pump Cel - 2nd Time - BMW Forum - BimmerWerkz.com
Old 05-12-2005, 10:26 PM   #1 (permalink)
martin1997m3 is an unknown quantity at this point
Two months ago I got a CEL. I used a Peake Research R5/FCX-11 to read the error codes - Table 16, Codes F5, F6 - Secondary Air System Flow too Low. I replaced the Secondary Air Pump and Valve at the Exhaust manifold. Everything has worked great until yesterday - I took the car out and drove approximately 60 miles. As I exited the freeway (thus the car was up to temp) I got a CEL. When I checked the codes - Secondary Air System Flow too Low (Cyl #4-6 only). I have verified the pump is working properly.
What else can cause this?
martin1997m3 is offline   Reply With Quote
Old 05-22-2005, 02:18 PM   #2 (permalink)
Check the filter
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
New Cai, But What About The Secondary Air Pump? BImmerN2B 3-Series (E36) 8 04-27-2005 07:43 PM
Secondary Air Pump Hootie361 3-Series (E46, E90) 0 03-30-2005 09:22 AM
Replacing Secondary Air Pump tiremann34 3-Series (E36) 1 01-17-2005 07:53 PM
