RTAB bushings etc... - BMW Forum - BimmerWerkz.com
Old 04-23-2012, 12:13 AM   #1 (permalink)
Car: 1998 M3/4/5
william0106 is on a distinguished road
ok, so I am not a mechanically inclined guy and I need to replace some bushings on my 98 M3/4/5. My question is what bushings do I need? I see a couple different ones, should I replace upper and lower?
I have already purchased the trailing arm mount bushings but I see more listed in the parts section. I apologize for my stupidity but any help with a lack of the usual helping of flaming would be appreciated. I frequent m3forum a lot and I know I would be destroyed asking this question there.
I would like to get as many bushings replaced as possible since the car will be down anyway.
Thanks in advance.
william0106 is offline   Reply With Quote
Old 04-23-2012, 12:51 AM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Well what parts you need depends on what your doing with te car. If your tracking t you would want different bushings then street use. Depending on how firm you want the ride to be.
Click HERE to see my E36 Blog
Old 04-23-2012, 12:10 PM   #3 (permalink)
Car: 1998 M3/4/5
street use only, just want it back to original specs.
Old 04-23-2012, 12:27 PM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
If you want it back to OEM specs then I recommend just going with OEM ones. They lasted this long so a new set should last just as long.
Check these out: OEM E36 M3 Rear Trailing Arm Bushings (Pair) - Vorshlag LLC
Has Anyone Tried Using a Slide Hammer to Yank RTAB Out From Flange Side IMSARS69 3-Series (E36) 1 08-16-2011 08:31 PM
Need Dimension of Slots on Either Side of E36 RTAB and Diameter of Bushing IMSARS69 3-Series (E36) 1 08-16-2011 08:28 PM
Rtab Tool mech9T8 3-Series (E36) 3 07-07-2011 08:56 PM
RTAB Replacement WillCall 3-Series (E36) 0 10-05-2010 01:38 PM
RTAB problems mech9T8 3-Series (E36) 6 11-15-2005 07:35 PM
