Right turn signals dont work?? - BMW Forum - BimmerWerkz.com
Old 04-01-2010, 09:26 PM   #1 (permalink)
ian3's Avatar
ian3 is on a distinguished road
Hey, I just bought a 1998 BMW M3. Literally a week after i bought it, all the right turn signals on the car didn't work for some reason. The corner, sidelight, and the turn signal on the brake light are not working. Sometimes they flicker for a second and then don't work again. What could the problem? Any advice would be helpful.
Thanks,
Ian
///M
ian3 is offline   Reply With Quote
Old 04-01-2010, 10:22 PM   #2 (permalink)
Since the left side works, I'd have a look at the signal lever switch contact for the right side. Do all the lights flash with the hazard turned on?
Old 04-01-2010, 11:47 PM   #3 (permalink)
ian3's Avatar
yes they do.......all of them work. It's just when i press the level up for the right turn signals none of them work..and the green light doesn't come on for the right turn signal either
///M
Old 04-02-2010, 12:03 AM   #4 (permalink)
That would then be the up side contact of the turn lever switch, I'd say.
Old 04-02-2010, 12:16 AM   #5 (permalink)
ian3's Avatar
So how would I fix that and can u give me some steps? Or is there a DIY info thing about it?
Thanks,
Ian
///M
Old 04-02-2010, 12:25 AM   #6 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
That does sound like the turn signal switch, ? though, have you checked all your fuses, the Bentley Manual shows 2 different fuses for the turn signals #23 5A & #34 fuses 15A.......also the #8 7pin relay controls the turn signals/hazards......I would pull it & reinstall it.......sometimes just the slightest corrosion will cause a poor contact.......also I assumed you have checked each bulb on the right side.....make sure none of them are burned out. I would do all this first before considering replacing that turn signal switch......
jb
Old 04-02-2010, 12:31 AM   #7 (permalink)
ian3's Avatar
yea the hazards work.....its just when i try to use the turn level for the right side lights of the car...they don't work.
///M
Old 04-02-2010, 12:37 AM   #8 (permalink)
I edited my previous post^
Old 04-02-2010, 12:47 AM   #9 (permalink)
ian3's Avatar
thanks alot.....ill try that
///M
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Turn Signals Majin 3-Series (E21, E30) 0 07-25-2005 06:37 PM
Question About Turn Signals LongHairedHippy 3-Series (E46, E90) 0 05-07-2005 10:34 PM
Turn Signals B3M2W5i 3-Series (E36) 6 12-22-2004 12:38 AM
Turn signals... akolang 3-Series (E36) 15 09-10-2004 08:32 PM
Paint for turn signals d3ity 5-Series (E12,E28, E34, E39, E60) 2 09-05-2004 11:35 PM
