Removing the Bonnet Badge - BMW Forum - BimmerWerkz.com
Old 07-25-2004, 05:00 PM   #1 (permalink)
JonDarwin's Avatar
JonDarwin is an unknown quantity at this point
How do I remove the bonnet BMW badge??
Thanks
Jonathan
JonDarwin is offline   Reply With Quote
Old 07-27-2004, 03:51 PM   #2 (permalink)
Wonderbread76088 is an unknown quantity at this point
Get a hair dryer (heat gun will work, but you have to be really careful) and point it at the badge. Be sure to move it around a little bit so you dont mess up the paint. Then get floss, or fishing line, and slide it between the body and the badge. If it doesnt slide with some effort, heat it up some more.
Sometimes there is some stuff left. Use goo gone or something (wd-40 works but not sure how it will affect paint) squirt it on a paper towel, and set it on the spot (make sure it is soaked good) dont rub it around. goo gone dissolves it, so if you move it, it wont work as good. Then... clean the area real good and wax it, just to be safe.
Have fun.
Wonderbread76088 is offline   Reply With Quote
Old 07-27-2004, 11:21 PM   #3 (permalink)
ARCHER is an unknown quantity at this point
Originally posted by JonDarwin@Jul 25 2004, 05:40 PM
how do you do this??
Thanks
Jonathan
To the best of my knowledge there is no adhesive under the hood/bonnet roundel. There are two pins that hold it in place - these can be accessed from the underside of the hood/bonnet. It is very simple to do. I have a DIY somewhere but will have t dig it up.
I think wonderbread is thinking of the "boot."
Me - '98 M3/4 (manual)
Estoril on black Nappa, UUC clutch stop, de-baffled airbox, Pilot Sports
Wife - '04 Discovery II
ARCHER is offline   Reply With Quote
Old 07-28-2004, 04:24 AM   #4 (permalink)
Mr White G's Avatar
Mr White G is an unknown quantity at this point
Clips in my experience
If you care try checking inside the hood.... if you don't then screwdriver ahoy!
<span style='color:blue'>&quot;So my BM makes me a flash bastard? Then I guess you're just keeping it real from the seat of your nova?&quot;</span>
<span style='color:gray'>&quot;...and the home of the brave..... is bravey 130bhp from a 7 litre engine? 100bhp/litre or don't bother building it!&quot;</span>
<span style='color:red'>&quot;Aaahh the UK; where every road is jammed, under construction, poorly maintained and unfairly policed, at least we don't get over-taxed for it........ HA HA HA!&quot;</span>
Mr White G is offline   Reply With Quote
Old 07-28-2004, 07:25 AM   #5 (permalink)
schilke's Avatar
schilke is an unknown quantity at this point
On the US 'bonnets' the roundel is held in by two rubber grommets on pins molded into the back of the roundel.
Take a flat head screwdriver, cover it with a rag and just pry it off.
Make sure if your're replacing it, to get new grommets too. prying them off will muck them up pretty good.
Need a new sig...
A BMW is for the soul, a Chevy is for groceries...
BAN KRAFTFAHRER!!!!
schilke is offline   Reply With Quote
Old 08-01-2004, 06:54 AM   #6 (permalink)
JonDarwin's Avatar
ta very much guys
Jonathan
Bonnet stuck closed - please help!!! KILOCHARLIE 3-Series (E36) 0 09-26-2005 04:31 AM
Hood / Bonnet Release KILOCHARLIE 3-Series (E36) 2 07-20-2005 02:23 PM
Swirl marks / paint damage on bonnet abajaj 3-Series (E46, E90) 8 05-09-2004 01:40 PM
7 Series Bonnet release cable broken munf 1,6,7,8 - Series and Mini Cooper 2 04-10-2004 09:49 AM
94 325is mod to m3 body kit with m badge? bmw_m3power 3-Series (E36) 20 10-09-2003 05:08 PM
