radiator - BMW Forum - BimmerWerkz.com
Old 06-22-2010, 09:17 AM   #1 (permalink)
k.sidlosky's Avatar
Car: 06 Ranger, 03 Accord, 96 m3 s52!
k.sidlosky is on a distinguished road
Send a message via AIM to k.sidlosky
radiator
I need a radiator ASAP! Where would be the best place to get one. Also the fan that sits on the motor side. Story time after I find one.
|Dinan Intake|Schrick Cams|24lb Injectors|809 HFM|M50 Manifold|TMS Stage IV+|Dinan Strut Brace|Samco Hoses|UUC Pulley||UUC SSK DSSR|DDM Coilovers|Fikse FM10|Brembo Rotors|Hawk Pads|AA Exhaust|Alpine|Audiobahn|Sony|
k.sidlosky is offline   Reply With Quote
Old 06-22-2010, 10:34 AM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
The usual suspects:
Pelican Parts - Porsche Parts & BMW Parts - Automotive Parts and Accessories - Porsche & BMW
BMW Parts and BMW Accessories | Bavarian Autosport
Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips
Turkey Fleet Bond Holder
Old 06-22-2010, 10:43 AM   #3 (permalink)
k.sidlosky's Avatar
On there way, ordered the radiator through bimmerworld for a total of 220 after shipping. The tan blade through pelican for a total of 40 after shipping.
Onto the story. Changed my valve cover gasket yesterday with some help. My help lost an extension turns out the extension was in the fan shroud, long story short, it ate my radiator and my fan. Back to driving the ranger...
Old 06-22-2010, 06:42 PM   #4 (permalink)
k.sidlosky's Avatar
So this is what I came out with
The blue spots are where the fan tore in. What's left of the fan is in front of the radiator. Took about twenty min to get everything out.
Old 06-22-2010, 07:18 PM   #5 (permalink)
drz
drz's Avatar
Car: zhp
Ouch
Old 06-22-2010, 07:31 PM   #6 (permalink)
Mr. Clean
BimmerE39's Avatar
Good god that sucks. I was going to say it might have been a good time to upgrade to one of these bad boys from Zionsville Autosport...
The "fatboy" radiator
Old 06-22-2010, 08:20 PM   #7 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Wow......that Fat Boy better go on a diet, $629.00 that's a whole lotta burger & fries!
jb
Old 06-22-2010, 08:25 PM   #8 (permalink)
Mr. Clean
BimmerE39's Avatar
jb
Hahah, but with the fatboy in your E36 your car will never sweat again...
Old 06-23-2010, 01:21 PM   #9 (permalink)
k.sidlosky's Avatar
Everything should be in today, pics of prior installation and finished product. Any tips on bleeding the system?
Old 06-23-2010, 02:58 PM   #10 (permalink)
10) It really helps to have a friend lend a hand by sitting in the car revving the motor and keeping an eye on the temp gauge. Start off by removing the coolant reservoir cap and the plastic bleeder screw right next to it. Fill the coolant reservoir with a 50/50 mix of coolant and distilled water. Have your friend start the car, turn on the heater to full hot on the vent position and rev the motor to about 2500 RPM, if the temp gauge goes past the 12 o'clock position, shut the motor off, let it cool down and start over again. Watch the coolant reservoir, as the engine warms up the coolant level should drop, refill as the coolant is sucked out of the reservoir. Watch the bleeder screw hole also, when coolant with no air bubbles begins to overflow then you're almost done. It's a good idea to have some paper towels handy to mop up any overflow. Screw the bleeder screw back in (be careful to not break the plastic screw) and continue to rev the motor, you should see a continuous stream of coolant spraying in to the reservoir from the small hole at the top. Continue letting that spray in to the reservoir while your friend revs the motor for a couple of minutes, until the gauge hits the 12 o'clock mark, to ensure any remaining air is gone. If the heater is blowing hot air when you're revving the motor AND when the engine is at idle then your cooling system is properly bled. If your vents are blowing cool air at idle then you still have air in the system, try revving the motor more and/or squeeze the radiator hoses to help dislodge any trapped air. Once your system is fully bled, top off the reservoir and replace the cap. Check the coolant level in a day or two and top off as needed.
jb
Old 06-23-2010, 03:01 PM   #11 (permalink)
k.sidlosky's Avatar
Wow, that was in dep. Thanks though, good memory refresher.
Old 06-23-2010, 07:43 PM   #12 (permalink)
k.sidlosky's Avatar
No radiator today.... def tomorrow.
Old 06-24-2010, 12:19 AM   #13 (permalink)
k.sidlosky's Avatar
Well 8pm it got here. Installed, forgot pics, still waiting on the fan.
Old 06-24-2010, 06:05 AM   #14 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
That's what I just ordered, still got to figure out the cheapest way to get it Downunder. Lifetime warranty on these units, so if you are planning to keep your car for 5 years, its probably worth the angst when you factor in a failed radiator on a trip. No more plastic end tanks or expansion bottles for me.
Old 06-24-2010, 08:41 AM   #15 (permalink)
k.sidlosky's Avatar
It is very sexy, looks like you would have to make shift brackets for the shroud.
Radiator Swap From 87 325i To Later Radiator From 89 325i TOMMYSPANNER 3-Series (E21, E30) 0 04-10-2010 12:50 PM
Radiator help, please!!! jayturk99 3-Series (E36) 6 06-28-2009 09:29 PM
How Much For New Radiator? afrochapin 5-Series (E12,E28, E34, E39, E60) 1 05-07-2005 01:00 PM
Radiator moe_j 3-Series (E36) 5 04-02-2005 12:21 AM
Radiator Help dberger 5-Series (E12,E28, E34, E39, E60) 4 07-07-2004 08:36 AM
