Questions about replacing items on an M3 - BMW Forum - BimmerWerkz.com
Old 08-07-2006, 08:54 PM   #1 (permalink)
MrDeception is on a distinguished road
Totally new to this forum
i am looking @ getting an M3 but the one that i am looking at has the following problems:
here is the owners offical description
"the speedometer guage works only about half of the time and lights up about half of the time. The odometer still works correctly. The drivers side seat is torn and could use replacing. This would be a great time you enthusiasts to put in racing seats with harness belts. The A/C has been playing up lately it works and then will shut off. When it works though it is cold air blowing out. And the final thing about the car is that the alignment and the tires need to be checked out."
he is asking $8000 for the car with 100k on it
how much is this going to cost to replace and i don't mean taking it to the dealership either. also does this seem like a good deal or should i keep looking and not bother with it?
MrDeception is offline   Reply With Quote
Old 08-08-2006, 06:56 AM   #2 (permalink)
paco1076's Avatar
Car: 1997 BMW M3
paco1076 is on a distinguished road
Send a message via AIM to paco1076
What year is the car? The a/c cutting off and on could be a low freon charge issue or one of the pressure sensor is failing. The speedo cutting off and on scares the crap out of me.
1997 E36 M3 - running stocker style right now...
paco1076 is offline   Reply With Quote
Old 08-08-2006, 10:40 AM   #3 (permalink)
its a 96
Old 08-08-2006, 10:49 AM   #4 (permalink)
/Banned
preyash's Avatar
Car: Audi
preyash preyash preyash preyash preyash preyash preyash preyash preyash preyash preyash
Send a message via AIM to preyash Send a message via MSN to preyash Send a message via Yahoo to preyash
I would say if u are spending 8k why get a car which already has problems, i would say keep on looking, im sure there are always good deals comin, i would say, even after getting the m3 for 8k and have problems, it'll be better getting a reliable honda and being happy with it.
so good luck
check out these websites
www.autotrader.com
www.cars.com
www.autoshopperonline.com
make sure u refine ur search.
IM me if u really want me to help you AIM is preyash123
preyash is offline   Reply With Quote
Old 08-08-2006, 08:56 PM   #5 (permalink)
LYFE SUCK5
Ivan's Avatar
Car: 2008 Infiniti G35
Ivan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant future
Send a message via AIM to Ivan
those sound like relatively minor problems given the price.
Ivan is offline   Reply With Quote
Old 08-09-2006, 12:30 AM   #6 (permalink)
Moderator
Dirty_Tool's Avatar
The biggest issue I would be concerned about is the speedo. Mostly because if it is intermittently not working.. then it may also intermittently not be counting miles. Also if it is a faulty cluster then you will be looking at a hefty price to replace the M specific instrument cluster which costs more than the non-M version. I would at the very minimum run a carfax on the car and try to determine if the reported miles goes in line with what the Carfax reports shows.
The next item: Drivers seat torn. if its just a small tear or cracking then it can probably be repaired by a mobile upholstery repair guy fairly cheap. If it has large tears and you need to replace the leather or the seat itself you will find that it costs a fortune. Leather upholstery work is not cheap especially when you have a seat with custom m flags woven in to the leather.
My opinion on aftermarket "racing" seats: fugly
Next issue AC: if the blower fan is shutting off intermittently then it could be a few different things.
1) faulty blower fan itself about $450 or so to replace
2) faulty blower resistor/final stage $1-200 to replace
3) faulty control module (IHKA) $4-500
(all ballpark prices)
Last item Tires and Alignment: Tires-depends on brand etc
Alignment- Best to have done at a dealer who will load the car down with the proper weight and measure the ride height which is vital to get the correct specs. $180-200
beyond that it may need front end bushings or control arms or other suspension components in order to properly align it especially with 100k miles (possibly 140k if the speedo hasnt worked for 2 years)
My opinion: Sounds like the owner is trying to dump a money pit. If you can do a lot of the work yourself and have connections for getting parts cheap or a good local BMWjunkyard then it may be worth buying PROVIDED that you can get a realistic idea of the true mileage of the vehicle.
If you are a guy who will have to take it to a shop and pay retail for all of this then I'd pass.
Good luck,
DT
Old 08-09-2006, 11:45 AM   #7 (permalink)
thanks for you imput guys
Bimmer n00b questions angryrobots 3-Series (E21, E30) 4 12-09-2007 11:08 PM
Buying First Used Bmw, Have Some Questions ynotony 3-Series (E36) 1 06-06-2005 03:17 AM
1995 and 2004 Stereo Questions dmccall Audio and Electronics 1 06-12-2004 11:13 PM
Questions about E39 speakers mrogers Audio and Electronics 4 04-03-2004 09:36 PM
