question on brake cooling ducts-E36 M3 - BMW Forum - BimmerWerkz.com
Old 12-07-2009, 09:18 AM   #1 (permalink)
Car: '99 E36 M3
M3dina is on a distinguished road
i installed my coilovers are removed the plastic from the wheel wells. but now, the brake cooling ducts are kind of rattling around. i want to remove the ducts, but there's a set of wires plugged into the ducts. what is that plugged in and can i unplug it without anything bad happening? or should i just zip-tie them to something and leave them there?
thanks,
chris
M3dina is offline   Reply With Quote
Old 12-07-2009, 09:22 AM   #2 (permalink)
If you can, I think it's best to leave the ducts in place. The wiring could be for the outside air temp sensor.
Old 12-07-2009, 09:25 AM   #3 (permalink)
Car: '99 E36 M3
alright so i should try and find a way to secure them so they're not making all kinds of noise.....
Old 12-07-2009, 09:42 AM   #4 (permalink)
Yeah, I think that's best.
Old 12-07-2009, 10:12 AM   #5 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Just seconding witeshark's input: the ambient temperature sensor is installed in the brake cooling ducts in the E36. Try to keep them in. Rethink how you put it all back together, as you may have missed something, given that it was all snapped into place when you started.
Good luck!
Turkey Fleet Bond Holder
Old 12-09-2009, 11:03 AM   #6 (permalink)
Car: '99 E36 M3
Good luck!
i decided to just drill holes in the brake ducts and zip tie them to the body. it still makes a little noise, but nothing compared to the way it used to be. the rattling noise is coming from where the brake ducts insert into the front of the bumper......
Old 12-09-2009, 06:27 PM   #7 (permalink)
drz
drz's Avatar
Car: zhp
problem solved!
Old 12-25-2009, 10:51 AM   #8 (permalink)
jeffhall009 is on a distinguished road
I am also looking for the same problem help but still not having any kind of solution of it.
BMW Accessories
jeffhall009 is offline   Reply With Quote
E36 Brake Upgrade and Rim Size Question hacker 3-Series (E36) 4 01-21-2010 06:16 PM
M3 Front Bumper + Non-M3 Brake Ducts? rwall23 3-Series (E36) 2 07-05-2007 03:20 AM
Brake Ducts and Lower Molding rwall23 3-Series (E36) 6 06-08-2007 09:40 PM
stock m3 "brake ducts" 4evrwyntr 3-Series (E36) 9 04-19-2006 03:03 AM
Brake Ducts wulley1 3-Series (E36) 4 03-05-2005 07:14 PM
