Question about the M3's tranny - BMW Forum - BimmerWerkz.com
Old 08-03-2004, 04:39 PM   #1 (permalink)
dennisjai is an unknown quantity at this point
hey fellas im a newbie =] can someone elaborate on the differences between a MANUAL Tranny and a SMG Tranny (Sequential Manual Gearbox) for the BMW m3?
thanks
dennisjai is offline   Reply With Quote
Old 08-03-2004, 05:20 PM   #2 (permalink)
M3Rider is an unknown quantity at this point
First off, welcome to the forums
The manual transmission has 6 gears plus reverse, and from what I hear its clutch is a little heavy, but the car is after all, high performance. The SMG tranny only has a reverse, neutral, and +/- gears. The +/- gear has 2 modes, Sequential and Automated. The sequential mode has 6 drivelogic programs which are different transmission programs that control shift speeds, ideal shift point, and so on. In this mode, you may use the lever or the paddles on the steering wheel to change gears. The right paddle upshifts, the left paddle downshifts. The automated mode has 5 drivelogic programs, which act the same way as the sequential program in that they both control shift speeds, and shift points, and so on. However in automated mode, the SMG system shifts the gears for you kinda like an automatic. The one big difference between the Steptronic Automatic Gearbox and the SMG, is that the Steptronic Transmission has a torque converter which "eats" horsepower" and does not have a true electronic clutch like the SMG system.
Which one is better you ask?? I'd go for the SMG because of the unbelievable fun you will have driving like an F1 driver, and because of its lightning fast shifts in Sequential Mode 6. The SMG also helps in stop and go traffic, because you can just pop the shifter into automated mode and the computer takes care of the rest. However if you want a stickshift and are not willing to fork over the extra 2,400 for the SMG option, then just get stick.
My Car
2004 330ci
Exterior: Alpine White
Interior: Black
Options: <span style='color:red'>Performance Pkg</span>, <span style='color:green'>Cold Weather</span>, <span style='color:blue'>Xenon</span>, <span style='color:yellow'>Moonroof</span>
M3Rider is offline   Reply With Quote
Old 08-03-2004, 05:41 PM   #3 (permalink)
i see.. thanks for the very detailed apply although i got confused abit.. did u mean the AUTOMATED tranny that u dont have to do anything eats alot of horsepower?
edit: also the - gear is the one where u change gear by urself
and the + is where it does everything for u?
thanks again!
Old 08-04-2004, 12:45 AM   #4 (permalink)
No, the SMG transmission does not have a torque converter which eats a lot of horsepower, regardless of what mode it is in. An automatic transmission with park, rever, neutral, drive, has a torque converter and that eats up HP.
No, the - on the lever is used to downshift, and the + is used to upshift. To change from sequential to automated mode, you would nudge the gearshifter to the right, let me draw you a diagram...
(N)__(+/-)-o
® = reverse gear
(N) = neutral gear
(+/-) = Upshift or Downshift
o = Change transmission mode
If you still don't get it, check out SMG and then click on SMG Drivelogic
My Car
2004 330ci
Interior: Black
Old 08-04-2004, 01:30 AM   #5 (permalink)
hehe i see i went to the website and read all about it but just a bit confused because of that bar thing but its all good =D
Old 08-04-2004, 03:27 AM   #6 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
that may indeed be the speed of the shifts... up would mean slower shifting, not going fast ish...
the shorter the jerkier/faster
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 08-04-2004, 03:28 AM   #7 (permalink)
skawful's Avatar
and an interesting thing: how to launch:
stop. push the shifter forward and hold it there... rev to 3500 i think and let back into the normal position (the shifter that is)
Old 08-04-2004, 09:06 AM   #8 (permalink)
i thought the normal position was automatic
Old 08-04-2004, 02:03 PM   #9 (permalink)
ex owner/admin
Furious's Avatar
here read this about smg it will clarify for you .
http://www.bmw-forums.com/forum/topic14951.html
Old 08-04-2004, 02:08 PM   #10 (permalink)
350z
Car: 03 Nissan 350z Track
awwww so beautiful! welcome to the forums!
David
**BAKER POW REPORT**
Old 08-04-2004, 06:57 PM   #11 (permalink)
thanks all for your help now i just wanna get the AUTO part fully correct
on the BMW website you have this bar thing as shown on the picture below
so i guess you click the button to change style like if u wanna drive eco or sporty or full power?
edit: so can like someone explain from gear 1 - 5 or was it 0-5 i dunno but can someone explain those gears a bit as the website isnt so clear
Old 08-04-2004, 09:50 PM   #12 (permalink)
I think you're referring to the drivelogic programs not gears. In automated there are five programs, right below the shifter, there is a button that looks like this:
\/ [][][][][] /\ the \/ arrow selects a lower program, while the /\ arrow selects a higher program. Program A1 (Automated 1) has slower more economic shifts, and is basically for neighborhood driving. Higher programs like A5 (Automated 5) provide faster shifts like when you wanna go on a highway and don't want jerky shifts.
As for launch control, here is the step by step:
Step 1: Stop the car completly, no acceleration or movement. Turn off DSC and choose sequential mode 6.
Step 2: Pull the left paddle on the steering wheel OR hold the shifter in the - position
Step 3: While - is held down, fully open your throttle (gas all the way down)
Step 4: The RPM will automatically go to 4,500 RPM in cars with the European software, but with the US software, i believe it is lower.
Step 5: Release the shifter from the - position (or let go of the paddle) and keep the gas pedal fully depressed. Be prepared to upshift since the car will violently accelerate.
Note: If you have the US software installed, doing this more than twice will void your warranty, so try to get the dealer to install the European software and do this to your heart's content, but be sure your engine is broken in (has a few miles on it).
Hope this helps, B)
My Car
2004 330ci
Interior: Black
Old 08-05-2004, 03:18 AM   #13 (permalink)
AlpineWhiteE46's Avatar
AlpineWhiteE46 is an unknown quantity at this point
Send a message via AIM to AlpineWhiteE46
Are you sure that doing this twice will void the warranty? According to this Popular Science article, it is illegal to void warranties on something like this, which is why the RPM limit is only ~1800 on US software:
But there is a catch. In Europe, where the feature isn't so hush-hush, doing more than 15 launches voids the car's warranty. Federal laws prohibit such stipulations here, so BMW has turned down the wick. U.S.-spec cars are programmed to wind to only 2,500 rpm—and our test car topped off at 1,800. That's why you have to ask your dealer to install the European software. Most will happily oblige.
http://www.popsci.com/popsci/auto/article/...,358540,00.html
I hope you're wrong 'cuz I've done it about 6-7 times. (It's really fun, btw)
Are YOU a Lost Cherry? Find yourself at LostCherry.com. I did: lostcherry.com/dave
AlpineWhiteE46 is offline   Reply With Quote
Old 08-05-2004, 05:06 PM   #14 (permalink)
Another correction: This hard launch does NOT work from the paddles. Only from the stick.
Old 08-05-2004, 07:34 PM   #15 (permalink)
Not too sure about that, have you tried it???
My Car
2004 330ci
Interior: Black
Manual Tranny Oil Question bkcraun 3-Series (E36) 3 01-07-2005 08:24 AM
Quick Question On M3's leftone M-Series (M1, M3, M5, M6) 2 10-12-2004 12:22 AM
A Tranny Question LinxJinx 3-Series (E36) 1 10-09-2004 02:13 PM
Manual tranny question jrhaile 3-Series (E36) 8 06-05-2004 01:50 PM
