Poor brakes - BMW Forum - BimmerWerkz.com
Old 08-17-2004, 03:49 PM   #1 (permalink)
FMV
FMV is an unknown quantity at this point
Anyone have any ideas? I just put New Euro Rotors OE and Padig blue pads on the front and OE rotors and Metal Master pads on the back. Then had my bro's dealer (he is the GM for Porsche dealer in Tulsa) bleed the whole system.
The problem, I have to step hard on the pedal to get any good braking results. I had better braking with the old worn out pads and rotors? I have used them for about 800 miles of stop and go driving. I think they should be broken in by now. Any tips or things to try.
Not that everyone will agree with my parts choice, but nonetheless, I should be happier with the cars braking than I am.
BTW - 98 M3 Coupe 50K miles
Thanks
FMV is offline   Reply With Quote
Old 08-17-2004, 10:17 PM   #2 (permalink)
roloson's Avatar
roloson is an unknown quantity at this point
Inspect all the brakes. All four. You may not be getting full braking from both fronts requiring higher pedal preasure to stop. You will need to pull the tires off so you can get a good look at the pads. see if wear is even from side to side. Also check vacumn to the brake system. It sound like you had a qualifed installer. You may want to ask him. I am not sure about ABS electronics and if that could be an issue.
Shoot Bear When Bear In Season
2004 M3 LSB SMG II Rolling on 19s
"The Thrill"
roloson is offline   Reply With Quote
