noisy fan - BMW Forum - BimmerWerkz.com
Old 01-12-2006, 05:02 PM   #1 (permalink)
Blackoutmp is on a distinguished road
noisy fan
i just picked up my 97 M3 and it only has 43,000 miles on it. the fan seams to be really loud. when you excelerate and the revs come up, the fan just gets louder. its annoying, i always hear the fan. even at 60mph just cruzing, i still here it humming up front. anyone have any suggestions?
Blackoutmp is offline   Reply With Quote
Old 01-12-2006, 08:52 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
I assume you mean the belt-driven fan rather than the electrical auxiliary pusher fan. You might check the fan clutch. If there is brownish-looking dust on its vent fins or if it wiggles back and forth slightly when the car is running, then you have a busted fan clutch. This is a common ailment on our cars. I replaced mine a few months back and it cost me about $250.
Lindsay fan club member.
Old 01-12-2006, 11:03 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Your fan should not be making that noise... does it spin freely with the engine turned off?
Les
1997 E36 M3 1990 E30 325i
Old 01-13-2006, 09:18 AM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
I did a small write-up on the clutch fan test procedure. It's located in the 6,7,8 series forum...
Hope it helps,
it's under the topic "aux fan not turning on"
LOS
Old 01-13-2006, 10:00 AM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
There is something very similar in the Bentley manual... I suggest getting one if you havnt already.
Good luck,
Les
Old 01-19-2006, 11:54 AM   #6 (permalink)
JEllis is on a distinguished road
Simple Solution... Do the fan delete mod for $80 and pick up 8Hp at the same time
Jason
1998 Arctic M3 Coupe- Custom Eurosport Intake, UUC TSE Gen 1 Exhaust, UUC Clutchstop, UUC RK6 Shift Knob, GC Front Endlinks, MaxVelocity GTR Front Lip-ON THE WAY: TEIN BASIC COILOVERS, OE STAMPED STAGGERED LTW WHEELS
JEllis is offline   Reply With Quote
Electric fan swap on 89 325i , need help/advice Slow325i 3-Series (E21, E30) 4 01-05-2006 08:10 AM
auxiliary fan always on mob_intl 3-Series (E46, E90) 1 11-22-2005 12:03 PM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
