New member, clutch slave question! - BMW Forum - BimmerWerkz.com
Old 11-17-2009, 09:35 AM   #1 (permalink)
esc97m3 is on a distinguished road
Hi guys, new member here. I've got a 97 M3 sedan with somewhere around 175k miles. I'm replacing the clutch slave on it and the new slave came with a rod. I'm assuming it's a replacement rod for the one inside the transmission that goes into the slave. My question is how do you get the old rod out? (it's not sticking out of the hole, it's kinda deep in there). I looked at some manuals (like the Bentley one) but no info on how it's removed. And I didn't want to stick some needle nose plyers in there and yank it out without asking if there's a more proper way to do it.
It also feels like it has a large rubber gasket on it or something, not sure exactly since I'm going only by what I can feel. I can only see the tip of the rod in there, and it doesn't seem to move when you press and depress the clutch pedal.
Thanks in advance for any info you guys can give me on this!
esc97m3 is offline   Reply With Quote
Old 11-17-2009, 10:13 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I thought the rod was part of the slave cylinder and should come out attached to the old one, unless its broken off/come detatched??? I may be wrong so wait for some more input...
Old 11-17-2009, 10:20 AM   #3 (permalink)
Well I was thinking it would come out with it too, but it seems to be stuck in there. I can't just pull it out with my fingers so I'll need a small pair of pliers to pull on it, I just wanted to make sure it was *supposed* to come out.
Oh and from what I can see of the tip, it doesn't seem to be broken. I guess it just came detached from the cylinder (which, thankfully was my clutch problem). I suppose I'll see what I can do with it.
Old 11-17-2009, 10:31 AM   #4 (permalink)
After going out there and prying around, the rod definitely seems to be being held in the transmission by something. Does the clutch pedal need to be pressed in to release it? Or does the car need to be out of gear? Can't figure out what's holding it in there.
Old 11-17-2009, 11:36 AM   #5 (permalink)
UPDATE: after getting a good grip on the rod with a pair of pliers and pulling as hard as I can, the rod still won't come out of the transmission. I've tried it with the clutch pressed and depressed. Can anyone possibly think of a reason the rod won't come out?
Just tried it with the car out of gear as well. Doesn't seem like this thing is going to come out easy unless I'm missing something here...
Clutch Slave Cylinder Bom356 3-Series (E21, E30) 7 02-13-2008 01:19 PM
Clutch Slave Cylinder flipsgonetopless 3-Series (E21, E30) 2 12-13-2007 09:41 PM
clutch slave cylinder? jfertita 3-Series (E21, E30) 2 02-28-2007 07:07 PM
New Poster -- QUICK HELP! E36 Clutch slave cylinder question Michael Yount 3-Series (E36) 7 01-24-2006 03:31 PM
CLutch cyclinder slave BmWNoobie 3-Series (E21, E30) 0 10-07-2003 01:35 AM
