MY AC sucks - BMW Forum - BimmerWerkz.com
Old 07-22-2003, 04:31 PM   #1 (permalink)
cam540 is an unknown quantity at this point
It is so miserable to drive around in my car lately, something is wrong with the AC. It doesn't blow hard enough to keep the car cold at all. Does anyone have any sugeestions. It has always been like this but lately the temp has been up 15 degrees so it sucks.
Thanks in advance.
<img src='http://people.albion.edu/dbc10/images/w04.gif' border='0' alt='user posted image' />
<a href='http://http://www.licenseschoolusa.com/real-estate-book.php' target='_blank'>Real Estate Books</a> | <a href='http://www.spotya.com' target='_blank'>Spotya! Quick Cash</a> - Short term cash loans for online shopping.
<a href='http://www.licenseschoolusa.com' target='_blank'>Real Estate License</a> | <a href='https://www.linkedin.com/profile?viewProfile=&key=1629532' target='_blank'>My LinkedIn Profile</a> - Contact me
cam540 is offline   Reply With Quote
Old 07-22-2003, 07:48 PM   #2 (permalink)
donutchow is an unknown quantity at this point
is the temperature gauge in the car off? maybe the car is overheating or something. or maybe the car is on circulate and it's not circulating correct.
Founder of the 3 pedal club, the first actual club on BMW-Forums.
donutchow is offline   Reply With Quote
Old 07-23-2003, 03:36 PM   #3 (permalink)
m42technic's Avatar
m42technic is an unknown quantity at this point
Send a message via AIM to m42technic Send a message via MSN to m42technic Send a message via Yahoo to m42technic
BMW A/C sucks in general.
When was the last time you had your A/C system checked out?
<span style='font-size:8pt;line-height:100%'>James
'91 318is</span>
m42technic is offline   Reply With Quote
Old 07-23-2003, 06:46 PM   #4 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Get your AC system Charged. That's probably all you need.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 07-23-2003, 10:09 PM   #5 (permalink)
How much???? I have a warranty with the car, will I need to use it? Because the warranty has a $100 deductible.
Old 07-23-2003, 11:38 PM   #6 (permalink)
m42technic's Avatar
Couldn't tell ya, as I dont really know what is specifically wrong with your car...
'91 318is</span>
Old 07-24-2003, 01:03 AM   #7 (permalink)
DesmoBob's Avatar
recharging yourself will definitely cost less than $100.
http://www.bmw-forums.com/forum/index.php?...&st=0#entry8709
when you say "it doesn't blow hard enough," do you mean that the temperature of the air is warm? or the air is cold, but it isn't pushing a sufficient volume of it?
Old 07-24-2003, 01:13 AM   #8 (permalink)
The air is cold but when I turn the AC on full blast it only blows at the lowest speed.
Old 07-24-2003, 07:14 AM   #9 (permalink)
ex owner/admin
Furious's Avatar
im incline to agree with Bob, i think maybe you need a freeon recharge or your compressor is starting to go.
Old 07-24-2003, 12:37 PM   #10 (permalink)
DesmoBob's Avatar
ah, ok that is good info.
if it is cold, your compressor is fine, and you don't necessarily need a recharge, although that never hurts.
no air movement = fan is dying or microfilter is completely plugged.
when i get home i can look up the symptoms for you in the TIS. in the meantime, check the fusebox. there is a diagram inside the fusebox cover, and there are about 4 or 5 fuses associated with various components of the a/c, i can't remember offhand if one of them is the cabin fan.
microfilter is easy diy. but i've never worked on fan before, so i can't tell you how hard it would be. but i would bet that labor alone would exceed the $100 deductible, so it may be worth it to put it on the warranty (after you rule out microfilter).
Old 07-24-2003, 09:24 PM   #11 (permalink)
DesmoBob's Avatar
ok, i didn't find anything in the TIS.
but on the m3forum there was somebody who also has a 97 m3 with exactly the same problem, so i thought it was you.
anyway, somebody posted a reply, has something to do with the final resistor. i don't know if this is your problem, but it is worth a read anyway:
http://216.118.86.224/m3forum/showthread.p...&threadid=12777
Old 07-31-2003, 12:31 AM   #12 (permalink)
DesmoBob's Avatar
:vroom (bump)
update: what somebody said about the final stage resistor seems to have fixed the problem
Old 07-31-2003, 01:50 AM   #13 (permalink)
perfect des, thanks!! Looks like I need to order the part and get ready to fix this!!
Old 08-01-2003, 10:59 PM   #14 (permalink)
EXtech's Avatar
------>>>> REPLACE YOUR FIANL STAGE RESISTOR!! do you have an E46 or E36 ? Lemme know if you need help
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 08-02-2003, 07:24 PM   #15 (permalink)
Retired administrator
triggrhaapi's Avatar
Cam has an E36 M3/4 (1997 model year)
Addicted to Speed Since 1997
Radio Reception Sucks thaddeus 3-Series (E46, E90) 5 03-06-2005 02:45 PM
This Forum Sucks SHAHAB323IS North Central 0 12-20-2004 05:00 PM
My E39 Radio Sucks.... maxxym Audio and Electronics 5 09-27-2004 04:08 PM
