M5 Flat Battery - How do I get in ? - BMW Forum - BimmerWerkz.com
Old 08-30-2004, 08:47 AM   #1 (permalink)
M5 - woaaahhh is an unknown quantity at this point
Hi good people,
I really REALLY hope you can help. My 1990 M5 has a flat battery and I can't get in. I locked it remotely including deadlocks, went on holiday and now I can't get in any of the doors, boot or bonnet ! Any suggestions/help greatly appreciated.
M5 - woaaahhh is offline   Reply With Quote
Old 08-30-2004, 09:25 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
ok... its either the drivers door or the passengers... try both.. but lift the handel.. and then turn the key.. its the manual lock release... I'm not sure if you put the key in before you lift the handel then turn.. or if you lift then insert the key and then turn.. just make sure you keep the handel lifted while you turn... try it out.. and reply back if it works or not... it should..
Les
1997 E36 M3 1990 E30 325i
Old 08-31-2004, 11:07 AM   #3 (permalink)
R.I.P Steve aka fast 6
fast 6 is hated around these parts
big hammer
1967 to 2006 rip
fast 6 is offline   Reply With Quote
Old 09-23-2004, 01:44 AM   #4 (permalink)
valier is an unknown quantity at this point
Originally posted by M5 - woaaahhh@Aug 30 2004, 01:47 PM
Hi good people,
[snapback]176114[/snapback]
Just happened the same to me on mine. You could try first putting the key in , lift the handle and turning both clockwise and anticlockwise the key. Hopefully after long minutes...it should come (can take up to a nice hour patience). Personnally I heard that through Munich Legends in UK but it didnt work for me...so i ended smashing the driver side window and replace it by any second hand e34 window as they are all the same. If you smash the window though...tape it (that will avoid bits of glass everywhere in the car). that is all i can say. Take 20 minutes to smash and replace the window if you know what you are doing.
valier is offline   Reply With Quote
Flat Battery shakie1973 3-Series (E46, E90) 3 04-26-2005 04:04 PM
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
Trunk locked with Flat Battery cathylap 3-Series (E21, E30) 7 08-31-2004 01:08 PM
Car battery seems to goi flat....316i H reg JADYO1 3-Series (E21, E30) 1 12-16-2003 02:14 PM
