M3 E36 Power Windows Problem - BMW Forum - BimmerWerkz.com
Old 12-09-2004, 06:11 AM   #1 (permalink)
vijay is an unknown quantity at this point
hi
my m3 e36 version has the following problem.
the window should lift or lower as the door is opened or closed. this does not happen. in fact the window does not move at all when hitting the switch.
i can hear a clicking sound (from somewhere in the door panel) when i press the switch.
can i perhaps fix this myself. i have a basic understanding and am willing to save bucks to make this work. any advice??
thanks
vijay is offline   Reply With Quote
Old 12-09-2004, 12:30 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
so your saying the microswitch is working but the window isnt. just to be sure, does your interior light go out when the door shuts? could it be due to cold weather? i remember that my cars windows wouldnt jump when it was colder out.
Old 12-09-2004, 12:30 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Yes.. first step... go pop your hood... looking from front to rear... the top right of your engine bay.. is your forward fuse box directly infront of your firewall.... open it.. and look for the power window or something of that nature fuse... it is most likely blown... in fact... make sure anything that relates to your windows isnt blown too... that is the most likely fault.
Good Luck.. and I hope that helps ya,
Les
1997 E36 M3 1990 E30 325i
Old 12-11-2004, 11:07 AM   #4 (permalink)
juallhuce is an unknown quantity at this point
Originally posted by vijay@Dec 9 2004, 06:11 AM
hi
thanks
[snapback]246370[/snapback]
I'm guessing you have the convertible model? The window won't lower at all? If you hear your microswitch hitting(clicking)...you're probably ok with your fuses. That clicking is letting you know you're getting power to your window. Let me know exactly what it's doing.
juallhuce@gmail.com
juallhuce is offline   Reply With Quote
Old 12-12-2004, 10:01 AM   #5 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
how come ur guessing he has a convertible model, i don't get it used , and also the windows are supposed to go up and down a little when u open and shut the door, i thought that was because mine was old lol
2011 Mazda2
1990 Mazda Miata
Old 12-16-2004, 05:22 PM   #6 (permalink)
[snapback]248497[/snapback]
Sorry about that...I meant to say two door. My bad. Anyway, the original poster hasnt emailed me yet.
Old 12-17-2004, 02:09 AM   #7 (permalink)
DoTheDew is an unknown quantity at this point
Check fuses.
second
There is a switch for the window is in the door catch on the B-pillar somewhere in the middle. Check that if its not that you might need a new power window motor.
DoTheDew is offline   Reply With Quote
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Power Windows abnrgr 3-Series (E36) 2 11-23-2004 06:11 PM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
Power Windows, Sun Roof, & Door Locks mlangston 5-Series (E12,E28, E34, E39, E60) 5 07-15-2004 12:49 AM
