Lighting issues - BMW Forum - BimmerWerkz.com
Old 09-01-2003, 10:43 AM   #1 (permalink)
CMGO is an unknown quantity at this point
My pass side front turn signal light will not light up. It will work when the blinker is engaged but not when the driving lights are on.
The side markers also exhibit the same. The driver side corner light is fine, it lights up when the lights are turned on adn it blinks fine as well. But the others will not stay on.
I checked fuses ( hard to tell what goes where) and they all appear to be fine.
98 M3 BTW.
<img src='http://www.azkphoto.com/choices.jpg' border='0' alt='user posted image' />
05 WRX STi
-04 H2
--98 M3-SOLD &quot; I miss you dearly&quot;
---87 Porsche 944S
----94 Toyota 4x4
-----82 Yamaha XJ750 Maxim
CMGO is offline   Reply With Quote
Old 09-02-2003, 03:40 PM   #2 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
I'd re-check all your wiring harness, sounds like maybe there crossed some wheres'..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 09-02-2003, 04:21 PM   #3 (permalink)
my car does the same thing. those bulbs have dual filiment which means one can burn out where the other stays good, but the car wont indicate a dead bulb till both filiments are burnt out. so all you need is a new bulb, cheap fix. although there might be some bad wiring as well cause when i replaced my bulb that same driving light filiment burnt out again within a month
Old 09-08-2003, 05:45 PM   #4 (permalink)
UPDATE
THe turnsignal was blown out. the blb was toast.
The side markers however, should they light up with the driving lights or just when using the turn signals?
05 WRX STi
-04 H2
---87 Porsche 944S
----94 Toyota 4x4
Fuel issues? Car bogging! ReaverJam 3-Series (E21, E30) 5 10-04-2005 10:16 PM
Strange Lighting issues kestrel325is 3-Series (E36) 5 09-07-2004 02:18 AM
2000 740i Issues vevro 1,6,7,8 - Series and Mini Cooper 1 04-21-2004 01:07 PM
2004 X5 4.4i - transmission / throttle issues rting 1,6,7,8 - Series and Mini Cooper 0 03-30-2004 02:14 AM
Ambiant Lighting focusedonsound 3-Series (E46, E90) 2 02-03-2004 08:18 PM
