Help needed - bmw e36 m3 - BMW Forum - BimmerWerkz.com
Old 09-26-2010, 12:04 PM   #1 (permalink)
James e36 is on a distinguished road
Hey all, I have a 1994 bmw e36 m3. On sunday past i took it out a run and it ran great, no bother what so ever. I went on sunday nite too take it out again, and it would not start. It cranked but would not fire up. Got my cousin out who is a mechanic and we were sitting in it looking threw the internet and threw the manuals trying to figure out why it wouldn't start. The car at this time was hooked up to another car with jump leads, and all of a sudden there was a click, tried to start my m3 and it fired up no problem at all.
We took it that the battery was low in charge and therefore wouldnt start. But with it charging off the other car for a while it gained enough charge and fired up. So off we went yesterday (first day off work to do so) and bought a new battery and changed it over, grand fired up straight away without a bother.
I then took it out a run, maybe 30 miles at the very most, and as i was cruising along in 5th gear at 60 mph i felt the car chugg or juder forward, then it drove on as normal, but about 20 seconds later it judered again. This time mph and rev counters stopped at 40mph and 2,000 revs. Then they dropped to 0 on both and the car started to slow down. Then eventually the car died out.
We towed it too our garage, and were working at it today to try and find the problem. We checked the fuel pump, fuel pump relay, battery etc, but to no avail. The fuel pump is still working, we can hear it work and the car still cranks but will not fire up.
We hooked it up too a diagnostics computer and it gave out the following readings -
. 26 - injection sensor
. 25 - engine speed sensor
. 24 - error speedo signal
. 10 - clamp 15 v to high
. 13 - voltage peak device
. 15 - sri input error
Any one that is able to help, it would be very appreciated as we are both stumped. Some one suggesteed maybe the crank sensor?
Thanks James.
James e36 is offline   Reply With Quote
Old 09-27-2010, 02:48 PM   #2 (permalink)
k.sidlosky's Avatar
Car: 06 Ranger, 03 Accord, 96 m3 s52!
k.sidlosky is on a distinguished road
Send a message via AIM to k.sidlosky
Could be the altinator, check the voltage output with a voltmeter.
|Dinan Intake|Schrick Cams|24lb Injectors|809 HFM|M50 Manifold|TMS Stage IV+|Dinan Strut Brace|Samco Hoses|UUC Pulley||UUC SSK DSSR|DDM Coilovers|Fikse FM10|Brembo Rotors|Hawk Pads|AA Exhaust|Alpine|Audiobahn|Sony|
k.sidlosky is offline   Reply With Quote
Old 09-27-2010, 09:01 PM   #3 (permalink)
theluis's Avatar
Car: 1995 BMW 325i 5 Speed
theluis is on a distinguished road
yea have you had any wiring work done? like alternator, starter sound system or any kind of service work done to it?
theluis is offline   Reply With Quote
Old 09-29-2010, 12:46 PM   #4 (permalink)
Ok so bit of an update, were getting no spark. Also when we turn on the ignition were getting no pump run. However if we put power to the fuel pump we can here it working.
Does this era of m3 have an immobiliser as standard? If so were is it located?
Old 09-29-2010, 01:31 PM   #5 (permalink)
theluis's Avatar
There is most likely a fuse for the security system try disconecting it and while your at it check all the other fuses too
also about the no spark check the crank sensor
91 E36 Help Needed Please Justus 3-Series (E36) 6 11-07-2008 03:31 PM
e36 325is parts needed matt325is Classifieds Sell & Buy 2 10-08-2008 06:00 PM
Needed e36 ashtray!!!! stracer Looking For 2 11-19-2005 08:43 PM
Needed E36 coupe body parts mlo2583 Classifieds Sell & Buy 0 07-27-2004 06:42 PM
E36 Spec Website URL Needed. MarsBar 3-Series (E36) 6 06-14-2004 10:24 AM
