Having an Idle problem!!!! - BMW Forum - BimmerWerkz.com
Old 07-19-2006, 11:12 AM   #1 (permalink)
PrInG's Avatar
Car: 95 Dakar Yellow M3, 00 1.8T VW GTI
PrInG has a spectacular aura aboutPrInG has a spectacular aura about
Send a message via AIM to PrInG
Hey guys hope you can help. I just bought an e36 m3. And when I went to pick it up the guy claims that the idle control valve is sticking so it is idleing weird. It isn't as responsive sometimes when you rev it it will stick open for a bit and then come back down. Car runs great and High Revs. Any other suggestions. And if it is the idle control valve. Any body know the easiest way to tackle that beast. It is sort of in an inconvenient spot under the intake manifold. Anyone know a good way to get in there. Thanks
PrInG is offline   Reply With Quote
Old 07-21-2006, 01:47 PM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Clean your ICV. There's a DIY on this forum somewhere. Just search.
It's a fairly common problem.
Old 07-24-2006, 07:41 AM   #3 (permalink)
PrInG's Avatar
I pull the icv out.... cleaned it with some alcohol.. my symptoms changed. I started it up for about 3 minutes and it would idle at very low Rpm like it was going to die. a little over 500 then die unless I gave it gas. And it still hesitates to come back down after I rev it.. It sounds like there is a blowoff valve in there that is shooting out air right before it comes back down. Anyone have any of these symptoms that could lend me some advice.?
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
Old 07-24-2006, 08:21 AM   #4 (permalink)
Super Moderator
dutchbmw's Avatar
I have had the same troubles 1 month ago. I cleaned the ICV (see DIY) and it's running smooth now. Any way, I'll get a new one soon since they're only $40 (at least here in the Netherlands).
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 07-24-2006, 11:51 AM   #5 (permalink)
PrInG's Avatar
Try something like 200 bucks here in the good ol U.S of A did your throttle stick at all. Like when you revved the engine did it seem liek the car was letting out a deep breath ? oh yea. When you guys pulled your icv out. was it stuck. Cause mine seems to move freely. even before I took the alcohol and Q-tip to it. Any other suggestions ?
- Bow
Old 07-24-2006, 01:07 PM   #6 (permalink)
PrInG's Avatar
Never mind HAHA I pulled it out again to put a new hose on that had hole in it and I cleaned it out again. And WALA car runs like a champ... NOw I need a new water pump. Anybody know what that is gonna cost.?
- Bow
Old 07-24-2006, 01:50 PM   #7 (permalink)
paco1076's Avatar
Car: 1997 BMW M3
paco1076 is on a distinguished road
Send a message via AIM to paco1076
You can do a search on this site for the metal impeller water pumps. DON'T GET THE PLASTIC IMPELLER! I think I remember it being like $150 US
1997 E36 M3 - running stocker style right now...
paco1076 is offline   Reply With Quote
Old 07-24-2006, 05:39 PM   #8 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Check out www.autohausaz.com
You're looking around $60-80. I have bought other things from here and happy with their service.
LOS
Old 07-26-2006, 10:58 AM   #9 (permalink)
paco1076's Avatar
Car: 1997 BMW M3
Sweet. Thanks for the heads up LOS.
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
idle problem Ivan 3-Series (E36) 8 03-13-2006 10:33 AM
325i white smoke and idle problem puppie 3-Series (E36) 3 10-22-2005 07:57 AM
Idle Problem 93 325i 3-Series (E36) 21 12-07-2004 09:42 AM
