found compression test results.... - BMW Forum - BimmerWerkz.com
Old 04-03-2010, 09:02 PM   #1 (permalink)
Car: 95 BMW m3
m3newbooty is on a distinguished road
Question found compression test results....
well i had a compression test done a couple years ago on my 95 E36 M3, i couldnt find the receipt that had the results on it till today. the results are...
CYL/Result:
1 / 200
2 / 200
3 / 150
4 / 200
5 / 200
6 / 200
now i would assume there's something up with #3's results. what would be the next step in pursuing the issue? a leakdown test? and what else?
Also, since this test was done a couple years ago would it be better for me to re-do the test again now before pursuing any further?
i Dont know much about all this so im looking for some help/suggestions...please no criticism.
m3newbooty is offline   Reply With Quote
Old 04-04-2010, 06:50 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
what is the problem to start with???
#3 cylinder might be low but still acceptable and will not cause any undue problems, UNLESS the fault in #3 is a compression leak into the cooling system.
Weird Result From Compression Test. joshh 3-Series (E21, E30) 3 04-16-2005 08:24 PM
Dyno Results jefft 3-Series (E21, E30) 11 04-04-2005 08:50 PM
M3 Compression Test And Cooling System MadBMW M-Series (M1, M3, M5, M6) 0 03-10-2005 09:47 PM
Dyno Results Anyone? M3Daemon 3-Series (E36) 1 01-10-2005 11:59 PM
