Fan Runs After The Car Is Turned Off - BMW Forum - BimmerWerkz.com
Old 05-05-2005, 10:46 AM   #1 (permalink)
former_d1 is an unknown quantity at this point
Just bought my 2nd m3a (4door 98). The only things wrong with it were a power steering leak (needs some new clamps) and the auxiliary fan runs after the car is turned off. I had to disconnect the battery (could not find a fuse to turn it off).
Any ideas at to what may be wrong? Replays? Double temperature switch? Anyone else had this problem on a e36 m3?
former_d1 is offline   Reply With Quote
Old 05-05-2005, 12:27 PM   #2 (permalink)
GnnSk8's Avatar
GnnSk8 is an unknown quantity at this point
Send a message via AIM to GnnSk8
my fan runs too. its to cool downt he egine.. thats what i understand. it turns off after a while (max maybe 10-15 mins if uwere driving realllllly hard)
<img src='http://img47.echo.cx/img47/4721/smg2copy0zf.jpg' border='0' alt='user posted image' />
Proud Member of the &quot;Ran away from a cop and got away&quot;x2 Club
Proud Member of the &quot;Pulled over at above 90mph and let off with a warning&quot; Club...<span style='color:red'>bitches</span>
GnnSk8 is offline   Reply With Quote
Old 05-05-2005, 12:43 PM   #3 (permalink)
Rhyzz's Avatar
Rhyzz is an unknown quantity at this point
hmm the auxillary fan should continue to run if the car is very hot, so i'd be more concerned about your car overheating than the fan continuing to run
I believe E36 M3's have had problems in the past with there temp sensors? Also check your water pump to make sure your cooling is sufficient
Rhyzz is offline   Reply With Quote
Old 05-05-2005, 02:19 PM   #4 (permalink)
[snapback]341149[/snapback]
I let it run for about 40 minutes last night. Talked to my techs at bmw of little rock today. They said it would be one of the relays: k21 or k22. Normal speed relay and the high speed relay. A $16 dollar item. Hope they are right.
Old 05-05-2005, 07:28 PM   #5 (permalink)
GnnSk8's Avatar
[snapback]341176[/snapback]
hopefully.... then its only 516$ YAY (500 for labor lol)
Old 05-06-2005, 01:10 PM   #6 (permalink)
Originally posted by GnnSk8+May 5 2005, 07:28 PM--><div class='quotetop'>QUOTE(GnnSk8 @ May 5 2005, 07:28 PM)</div><div class='quotemain'><!--QuoteBegin-former_d1@May 5 2005, 11:19 AM
I let it run for about 40 minutes last night.* Talked to my techs at bmw of little rock today.* They said it would be one of the relays: k21 or k22.* Normal speed relay and the high speed relay.* A $16 dollar item.* Hope they are right.
[snapback]341275[/snapback]
[/b][/quote]
It was the normal speed relay. $16 item.
94 m-technic in AZ adamsbomb Cars For Sale 8 12-14-2005 11:43 PM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
