Expansion tank M3 - BMW Forum - BimmerWerkz.com
Old 01-15-2009, 03:41 PM   #1 (permalink)
kevinheap is on a distinguished road
Expansion tank M3
I have my radiator out on my E36 M3.
Should I expect an expansion tank with the ETD aluminum radiator and if not how critical is a new expansion tank, I like to go quality but have to watch money.
Why would you have to drain the entire system? The block coolant should be fine left alone right?
I found out that to loosen the fan on 3 cars the best tool is a thin screwdriver about 7" long as you can wedge it against the pulley housing and a nut and lock it straight above near the metal above the therm housing. Play around it is a sweet trick IMHO. I just used a cresent wrench on the 32m and it had foam on it to cushion the soft blow, real easy.
kevinheap is offline   Reply With Quote
Remove expansion tank - help needed! wpa 3-Series (E36) 2 08-11-2008 07:09 AM
expansion tank kakarat 3-Series (E46, E90) 4 03-03-2008 11:19 PM
expansion tank exploded (literally) cheripie 3-Series (E36) 16 11-08-2005 04:10 PM
Expansion Tank Leaking kvadgama 3-Series (E36) 1 05-14-2005 10:38 PM
Removing Expansion Tank From Rad? ballin 3-Series (E36) 1 11-14-2004 12:27 PM
