E36 M3 is moaning...help? - BMW Forum - BimmerWerkz.com
Old 09-12-2005, 07:34 PM   #1 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Hey,
My E36 M3 is intermittently moaning from right behind the instrument panel when I turn. Happens some days, doesn't happen other days. Do I guess correctly that my power steering pump is dying?
Lindsay fan club member.
Old 09-12-2005, 07:49 PM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Does the "moaning" go with the engine's speed?
Turkey Fleet Bond Holder
Old 09-12-2005, 07:54 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Can you hear this noise with the hood open?
How loud is it?... e36 tend to have noisey vent valves for the A/C. If you turn your air on and then completely turn it off you should hear the sound I'm speaking of.
Check those two including the one above.
Les
1997 E36 M3 1990 E30 325i
Old 09-12-2005, 08:20 PM   #4 (permalink)
Teh Prof's Avatar
It certainly doesn't. It just happens when I turn the wheel--and not always. Obviously it's more noticeable at lower speed (<20mph) than high speed, since I turn the wheel more at lower speed.
Old 09-12-2005, 08:23 PM   #5 (permalink)
Teh Prof's Avatar
Les
If I was standing 30 feet away, I'd have a hard time hearing it; from the inside of the car, it's about 1/4-1/3 the volume of what I can hear inside from the horn. Not sure how the hood affects things yet, as it has decided to behave today.
I don't think it has to do with the A/C, since I've heard it both with the A/C on and with the A/C (and climate control entirely) off.
Old 09-12-2005, 08:55 PM   #6 (permalink)
Retired administrator
triggrhaapi's Avatar
if the pitch of the moaning changes with the engine RPM then it's power steering. You may be low on fluid. Try topping it off a bit and see if it goes away.
Addicted to Speed Since 1997
Old 09-19-2005, 10:59 PM   #7 (permalink)
Teh Prof's Avatar
Your suggestion worked perfectly. Thanks.
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 01:39 PM
NEW E36 Rear Axel Bearings jroozee OEM Parts 0 11-06-2005 09:33 PM
F/s E36 Garage Sale!!!!! in_si1ence Classifieds Sell & Buy 0 11-02-2005 04:56 PM
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 04:27 PM
