E36 M3 ABS problem - BMW Forum - BimmerWerkz.com
Old 04-28-2006, 04:11 PM   #1 (permalink)
djhowie's Avatar
djhowie is an unknown quantity at this point
Thumbs up E36 M3 ABS problem
Hi everyone, Hope someone can shed some light on this problem for me.
I recently changed the front discs and pads for aftermaket items. Ive done about 500 miles with no problems until now. All of a sudden the ABS light has been coming on after a short distance. The car is due to go in for some warranty work on the rear suspension bushes but I dont know whether to mention about the ABS light in case they wont cover it due to using non BMW parts on the brakes,,, even though clearly the ABS sensors are not in direct contact with either disc or pad.
Is there any way of me testing each of the ABS sensors off the car with a meter to see if I can remedy the problem prior to me taking it into the dealer.
Thanks in advance
Howie
<img src='http://www.djhowie.plus.com/Howiecars.jpg' border='0' alt='user posted image' />
Porsche 944 turbo, 300+BHP &amp; never goes wrong.....BMW M3 Evo SMG, 320BHP never out of the dealers
djhowie is offline   Reply With Quote
Old 04-28-2006, 04:39 PM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
Thanks in advance
Howie
they arnt going to bitch you out for trading out the stock brakes... they probibly have done the same on thier rides... id ask if they would check for you anyways... and if they dont? then just get a different mechanic on the side... i dont think theres anyway you can check for yourself...
Old 04-29-2006, 02:47 PM   #3 (permalink)
boostinsixtwintturbo's Avatar
boostinsixtwintturbo is an unknown quantity at this point
Thanks in advance
Howie
Hello, I gathered this information from my expirience and thetrusty book. I have been in this situation before, non BMW.
i have some things here but may or may not help. Theres 2 versions of ABS systems on E36's. Earlier models use a Teves Mark IV G ABS. LAter models use
Teves Mark 20-1 ABS. The difference of both is that the later model integrates the ABS contorl module into the hydraulic unit as a single component. So basically you cant trouble shoot that part.
But , if you can, check for each ABS speed sensor thats on each wheel well, and check and see if its corroded , dirty or frayed or broken. Thats the easiest. You can repair broken wires.
You can remove the speed sensors and clean them with carb cleaner or similar. And check the tip of the speed sensor.
Also check the gap of the sensors to the toothed wheel hub.
Check the pulse sensor harness also. And coat it with some Molykote grease or something similar to it.
Hope this helps and if it doesnt then have it check at the dealer.
Cheers.
<img src="http://img514.imageshack.us/img514/3500/sig21zo.gif">
1995 M3
1994 Supra TT 6SPD (Gone)
1994 Supra TT a few goodies
2003 Infiniti FX
You dont need class to go fast, you need balls
boostinsixtwintturbo is offline   Reply With Quote
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
E36 Over Heating Problem :-( 325iserge 3-Series (E36) 4 03-06-2006 09:33 AM
Perplexing Problem Starting my 87 528e arkhaus 5-Series (E12,E28, E34, E39, E60) 5 02-04-2006 08:17 AM
e36 rear view mirror problem/ pop0tart 3-Series (E36) 5 12-12-2005 06:39 PM
E36 325i problem with power steering after doing doughnuts!?!? anar_325i 3-Series (E36) 10 10-12-2005 05:18 PM
