E36 M3 To 93 325i - BMW Forum - BimmerWerkz.com
Old 03-11-2005, 03:13 PM   #1 (permalink)
nookatee is an unknown quantity at this point
Send a message via AIM to nookatee
Does anyone know if the Exhaust (i'm talking headers all the way to muffler) off of a 2 door 95 M3 is compatible with a 93 325i. Also, if I get the springs from a 97 M3, will I notice much of a difference (ride height, stiffness, etc.). And finally, if I only install the front shocks from the M3, will that be a problem? i.e. can i keep the stock 325i shocks on the rear? Thanks much
nookatee is offline   Reply With Quote
Old 03-11-2005, 07:21 PM   #2 (permalink)
MadBMW's Avatar
MadBMW is an unknown quantity at this point
[snapback]309003[/snapback]
I think that you might have better luck posting this in the 325 forum area, because most people here only modify there M3 with aftermarket stuff. Someone that has a 325 and has done it might be able to tell you. I don't think that anyone in here has tried to put 325 stuff on there M3. Good luck in your search.
2002 Bmw X5 4.4I
1997 Bmw M3 3.2L
1988 Sunbird Eurosport SLC 5.7L
MadBMW is offline   Reply With Quote
Old 03-11-2005, 08:59 PM   #3 (permalink)
CiscoKid's Avatar
exhaust = yes
suspension = not worth it
the exhaust will work, but will no power differnece, just a better sound.
It would be cheaper to grab new springs and shocks made for your car... i would reccomend the cup kit.
DO NOT MIX AND MATCH THE SUSPENSIONS
Old 03-12-2005, 07:39 PM   #4 (permalink)
Originally posted by CiscoKid@Mar 11 2005, 09:59 PM
exhaust = yes
[snapback]309207[/snapback]
You don't think I can just put the springs from an M3 all around? And if I did, you don't think it would make much of a difference? Also...it's not cheaper to grab new shocks and springs for my car. That's why i'm considering doing this. If it were cheaper to grab new ones, I probably would have, dig?
Old 03-12-2005, 11:15 PM   #5 (permalink)
e36_m3_Turbo's Avatar
Originally posted by nookatee+Mar 12 2005, 06:39 PM--><div class='quotetop'>QUOTE(nookatee @ Mar 12 2005, 06:39 PM)</div><div class='quotemain'><!--QuoteBegin-CiscoKid@Mar 11 2005, 09:59 PM
exhaust = yes
[snapback]309796[/snapback]
[/b][/quote]
no the m3 suspenion was designed just for the m3 body.
No longer red.
Old 03-13-2005, 03:20 PM   #6 (permalink)
i thought the M3 body was just the E36 chasis. I think most of them were 2 door, but a 2 door E36.
Old 03-13-2005, 04:41 PM   #7 (permalink)
CiscoKid's Avatar
the suspension i set up differnatly
Old 03-13-2005, 05:59 PM   #8 (permalink)
[snapback]310389[/snapback]
tottally diff dude
No longer red.
Bmw E36 325i saloon subframe torn from floor Jaysdiff 3-Series (E36) 7 11-03-2005 11:31 AM
E30 325i Dinan Turbo vs E36 2.8l OBD1 jrhaile Video Vault 3 10-30-2005 12:41 PM
E36 325i problem with power steering after doing doughnuts!?!? anar_325i 3-Series (E36) 10 10-12-2005 05:18 PM
