Dynoed the M3 - BMW Forum - BimmerWerkz.com
Old 02-12-2007, 09:04 PM   #1 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
Question Dynoed the M3
this is a chasis dyno, i removed the wheels...so i have to weigh my wheels to do the equation to get my rough HP and TRQ
a guess is that i subtract about 15-20 hp...as someone on bf.c stated,
Originally Posted by SicNA94teggsr View Post
Dynapac's are from NewZeland, they call the rotors flywheels there.
my AFR is retarded, thoughts?
Old 02-12-2007, 09:22 PM   #2 (permalink)
Hoofhearted's Avatar
Hoofhearted is on a distinguished road
Wow your a/f does looks really weird! Do you have a fuel computer!
Hoofhearted is offline   Reply With Quote
Old 02-12-2007, 09:27 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I'd say the cut out at 5500 rpm with the dip in A/F is due to the drop out of the vanos unit... could be a faulty vanos valve... or sensor. Not a big deal...
Dude your putting down some damn good numbers... I'd be happy with those... but add about 30 horses and thats what I got... .. it looks normal... do so research for A/F on other M3's your year and mileage... and you'll probably have the same results... bf.c is a good start to search.
Good luck,
Les
1997 E36 M3 1990 E30 325i
Old 02-12-2007, 09:37 PM   #4 (permalink)
General Chaos
Car: ///M3,Corolla
Good luck,
Les
yea, im thinking vanos too, its been making alot of noise, i just picked up one of bf.c, i might pick up one more just in case....
Old 02-12-2007, 09:46 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Wait you bought a whole vanos... or just the vanos selenoid?
Les
Old 02-12-2007, 09:48 PM   #6 (permalink)
General Chaos
Car: ///M3,Corolla
Les
vanos and solenoid
100 bux...meh
Old 02-13-2007, 12:08 AM   #7 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
ya check the vanos unit but those numbers are about as good as you will get with a stock S50
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 02-13-2007, 12:41 AM   #8 (permalink)
General Chaos
Car: ///M3,Corolla
yea i know, i might re-dyno after replacing it...
Old 02-13-2007, 09:09 AM   #9 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
The numbers look about perfect for the car. I'd expect when you put it on a dynojet you'd put down 200/200.
I'm not a fan of dynapack's because a lot of people (especially on bf.c) try and show these numbers and claim them without telling people it's a chasis dyno. It cannot be used for comparitive purposes.
And those AFR's are all kinds of weird. What did they use? Was it a sniffer? Was it properly placed? Once again this dyno shop can go fuck itself. Go to a real one please because this doesn't look proper at all. And if so you're all kinds of lean to the point where it's scary and unsafe for your motor.
edit: i'm looking at your AFR's once again and that just looks ridiculous. Honestly something wasn't done right and I doubt your car has a problem. It's your dyno shop and their incompentency in my opinion. What was your AFR at idle according to them?
Old 02-13-2007, 09:41 AM   #10 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I completely forgot about A/F sensor placement... good point.
Les
Old 02-13-2007, 09:42 AM   #11 (permalink)
General Chaos
Car: ///M3,Corolla
they say the AFR reads about 1 point higher...which is still high...
Old 02-13-2007, 09:44 AM   #12 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Where did they put it?... was it a sniffer?... what the hell did they use... that matters a lot.
Les
Old 02-13-2007, 11:11 AM   #13 (permalink)
General Chaos
Car: ///M3,Corolla
Les
they used that piece that sits in the exhaust...is that called a sniffer?
Old 02-13-2007, 06:22 PM   #14 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Yeah it's a sniffer.
Seriously find a good dyno shop.
Old 02-13-2007, 07:22 PM   #15 (permalink)
fastshivy's Avatar
Car: 1999 540i
fastshivy is on a distinguished road
M power is the man...I doubt you would be putting up those numbers running that lean...then it runs rich and the power falls off?? Crazy stochiometric ratios
fastshivy is offline   Reply With Quote
Just Dynoed, too lean? Tochenzo 3-Series (E36) 21 05-02-2006 07:58 AM
Dynoed my 325i BMWJNKY 3-Series (E21, E30) 5 03-10-2004 10:55 PM
