Driver's Side Door Lock Broken? - BMW Forum - BimmerWerkz.com
Old 03-02-2005, 12:35 PM   #1 (permalink)
angryman156 is an unknown quantity at this point
I'm suffering from a small problem that's just big enough to be annoying. On my driver's side door, usually when I try to lock or unlock it, it makes that delightful little mechanical sound and easily turns over. Now almost every other time, it doesn't turn or turns about 15 degrees then refuses to turn, no more mechanical sound and nothing happens. If I use a little more force, it locks and makes a very very feint mechanical sound. Other times, it makes a dying mechanical sound and does its job, but its definitely not as easy to turn as it used to be. Is this a relay problem? a fuse problem? Tell me doctors and give it to me straight! Is this going to cost me my liver!? Oh, also I noticed this problem after I had a cd deck installed in my car, you think they screwed something up?
angryman156 is offline   Reply With Quote
Old 03-05-2005, 11:48 AM   #2 (permalink)
It sounds mechanical to me it's common for the lock barrel to seize up a bit of releasing oil into the barrel and work it back and fore should do the trick
318is Driver's Seat Release Lever Broken Cippico 3-Series (E36) 0 04-26-2005 09:24 AM
how to remove driver's side mirror? TheHire 5-Series (E12,E28, E34, E39, E60) 0 06-20-2004 04:31 PM
Driver's side mirror TheHire 5-Series (E12,E28, E34, E39, E60) 2 06-16-2004 12:10 AM
Driver's side mirror TheHire 3-Series (E21, E30) 0 06-15-2004 11:33 PM
NO DRIVER'S SIDE HEAT! PLEASE HELP! dnbmartin 3-Series (E36) 1 01-03-2004 09:03 PM
